Fiesta-Si.com • View topic - my 2ltr.. fault codes and overfueling.. help
It is currently Thu Mar 26, 2026 9:00 pm
PostPosted: Thu Dec 11, 2008 10:51 am
2 questions…
Basically my car was overfueling a bit on and off .. I think it might be electrical or the fuel pump as I can here the fuel pump relay going constant and the fuel pump is too.. Causing REALLY BAD idle and just spitting out petrol… dying when you drive due to overfueing.. I think its wiring or fuel pump shed anylight?!?
ALSO I tried to put a code read on my car using 3 plugs by the battery / headlight… it just comes up with undocumented fault ….and ou cant clear fault codes you have to fix the problem first or something… my car don’t even have an enginemanagment light so how you suppose to know when it fkkss up?!?!
HELP haha
PostPosted: Thu Dec 11, 2008 11:10 am
might sound daft but, have you tried replacing the temp sensor for the ecu? top of the thermostat as when thats shot it does cause some over fueling
what about your lambda? mine had a bad idle( would try and cut out alot when the rev's were down/low) and i replaced my lambda and it seemed to cure the issue
PostPosted: Thu Dec 11, 2008 2:35 pm
someone said lambda sensor...temp sensor.. near coilpack on top of like the water pump?! seems water is leaing from there you know
PostPosted: Thu Dec 11, 2008 2:43 pm
water pump is other side(drivers side) ;)
temp sensor is near the coil pack on top of the thermostat(passenger side), there are 2 sensors on the thermostat, one on the bottom is for the temp gauge
mine use to idle like shit so replaced that and it made it a bit better then had my cam timing done and it made it even better, but i dont think the cam's are your issue :lol:
iirc a new temp sensor from ford was £23 i think :look: try the lambda if you can get hold of a spare that you know is working
not sure on the fault code though :red:
