Fiesta-Si.com • View topic - fog light removal
It is currently Fri Mar 13, 2026 7:06 am
 Post subject: fog light removal
PostPosted: Tue Dec 02, 2008 12:01 am
hi, this may sound stupid . . . but can someone tell me how u remove tha fog lights from the bumper, can it be done with out taking off the front bumper? cheers
 Post subject: Re: fog light removal
PostPosted: Tue Dec 02, 2008 1:47 am
Wrong section I think mate but,
There is a phillips screw under each fog light, undo them and then take the covers off.
Then there are four bolts on each fog light, 10mm from memory, just undo them and bobs
your uncle. Then just disconnect the wires.
Emlyn
PostPosted: Tue Dec 02, 2008 9:55 pm
PostPosted: Tue Dec 02, 2008 11:42 pm
Are they? I'm pretty sure mine had bolts, but could have been non standard as they had
been changed. That makes it even easier then :)
Emlyn
PostPosted: Wed Dec 03, 2008 12:58 pm
yeah they all have screws as standerd but the heads usally rust so much when you try and turn the screw it just chews up :doh: bolts sounds a better idea tbh could be worth changeing the screws for bolts hmmmm
PostPosted: Wed Dec 03, 2008 11:17 pm
Yea, the adjusters on mine had basically rusted away so I replaced them all with bolts, much better now! Took ages to get surround bolts off too as they were seized! Had to drill them off in the end. It begs the question, wots wrong with stainless steel!!!!!!! :x :lol:
