Fiesta-Si.com • View topic - Exhaust
It is currently Thu Mar 26, 2026 7:29 pm
 Post subject: Exhaust
PostPosted: Sat Nov 22, 2008 7:27 pm
i removed the two bolts and took it out the hanger and the two pipes are rusted together what can you do to remove the pipes form each other
 Post subject: Re: Exhaust
PostPosted: Sat Nov 22, 2008 8:02 pm
Hammer. Lots of pulling, twisting etc. Maybe even some WD40.
If you dont need the exhaust you can grind into it so you can prise it open :)
PostPosted: Sat Nov 22, 2008 8:04 pm
were should i hammer
PostPosted: Sat Nov 22, 2008 8:06 pm
...the join where its stuck.
it will hopefully loosen it up enough so you can twist the exhaust. it will most likely be stiff as hell and take a while.. but as soon as you can twist it abit, it will eventually come off
PostPosted: Sat Nov 22, 2008 8:08 pm
thank you i will try it when i go out there next which wont be for a while
PostPosted: Mon Nov 24, 2008 8:41 am
Heat it up to help :)
PostPosted: Thu Nov 27, 2008 1:40 pm
as said hammer the joint and then try twisting the box to get it loose, also take the back box of its rubber hanger as that will give it more movement :thumbsup:
