Fiesta-Si.com • View topic - brake drum diameter ?
 Post subject: brake drum diameter ?
PostPosted: Fri Nov 21, 2008 6:29 pm
whats the brake drum diameter for the 1.6 si non abs cheers
PostPosted: Sat Nov 22, 2008 3:17 am
ford put 2 different sizes of drums on the si
ones look like this...which are the bigger drums
and this the smaller size
the bigger ones are flatter
PostPosted: Sat Nov 22, 2008 11:29 am
according to the Haynes manual 180mm on Si (mine are as just measured them) and 203mm on XR2i and ABS equipped models
PostPosted: Sat Nov 22, 2008 6:37 pm
According to haynes.... but my Si had 203mm drums (no abs etc etc) untill i ditched the mk3 axle for a Zetec S one (still undecided on brakes for the back)
PostPosted: Sat Nov 22, 2008 7:39 pm
my si has the 203mm ones then but has no abs
PostPosted: Sat Nov 22, 2008 8:00 pm
As with many things.. Ford did things randomly.
My RS1800 has the bigger drums.. to be honest they made no noticable difference.
Bad thing about them tho.. is if you bent one like I did, to find a quick replacement is hard.. so I went back to the more available smaller ones :)
PostPosted: Sat Nov 22, 2008 8:22 pm
How did u bend a drum?
PostPosted: Sat Nov 22, 2008 8:27 pm
