Fiesta-Si.com • View topic - water leak in passanger foot well
PostPosted: Tue Nov 18, 2008 11:05 pm
iv got a small leak intomy passanger foot well
i know this is common on mk4/5 fiestas and pumas but im not sure if its a common prob on the mk3.5
if it is wheres the common points
PostPosted: Tue Nov 18, 2008 11:11 pm
Heater matrix is prob leaking. When you put blowers on full to the floor does water come out?
Other than that could be leaking in from bulkhead. Either way id check your floorpan if its damp!
PostPosted: Tue Nov 18, 2008 11:36 pm
heater matrix is the more than likely one
or......
rotton under the carpet on the wheelarch (was the problem on my last fiesta)
rotton sunroof drainage holes(another fault that caused leaking on my last fiesta) the drainage pipes run through the body of the car and into the sill if i rememer correctly and they can rot if they get clogged up....
