Fiesta-Si.com • View topic - ST170 engine
It is currently Fri Mar 13, 2026 8:42 am
 Post subject: ST170 engine
PostPosted: Thu Nov 13, 2008 5:18 pm
whats involved in putting it in the car
Just want to use the block as Ive already got a fancy polished ported head and stage 2 cams
what about water pump, flywheel, sump, pick up etc......
any info appreciated
 Post subject: Re: ST170 engine
PostPosted: Thu Nov 13, 2008 6:50 pm
i believe the head will fit straight on to your 2.0silvertop bottom end
PostPosted: Thu Nov 13, 2008 7:43 pm
Should fit exactly the same as its just another 2.0ltr zetec engine.
The standard ST170 engine just has better internals and VVT (forged pistons etc)
But as your wanting to fit your fancy polished head with cams then you won't have the VVT feature.
Still, it'll be better than a standard 2.0ltr silvertop block.
Same gearboxes fit :)
So its basically just a straight swap as fair as I'm aware.
edit: maybe have to swap sumps over
I'm tempted to get a 170 engine hmm
PostPosted: Thu Nov 13, 2008 11:52 pm
Im using the bottom end , and the complete head will be for sale
the sump I think is a baffled item, , Ill take it off and have a look, and if it baffled , Ill just have the ill return line for the bailey breather set up welded in
What about the water pump, anyone know, as Id like to fit the brand new zetec one I just bought and it would simplify the belt and alternator set up
PostPosted: Fri Nov 14, 2008 2:26 pm
Gearboxes are different paul, St170 is 6 speed! :)
PostPosted: Fri Nov 14, 2008 2:59 pm
PostPosted: Fri Nov 14, 2008 6:10 pm
talk to jimmyesh on FT, :thumbsup:
PostPosted: Fri Nov 14, 2008 6:20 pm
thought the ST170 engine was just a Series 3 (blacktop) zetec with a fancy head, inlet, and VVT? with the bottom end being a normal 2ltr blacktop?
i may be and probably am wrong though.
PostPosted: Fri Nov 14, 2008 7:02 pm
link to his latest project thread a 2.3 duratec turbo in a mk3 fiesta :)
Also built the MANJ, ST170 engine with 6 speed box IIRC :thumbsup:
PostPosted: Fri Nov 14, 2008 7:22 pm
i thought the st170 had equal length driveshafts from the inner cv joints, and that the o/s driveshaft went through the sump same as on a range rover??
http://WWW.S2RS.CO.UK
PostPosted: Sat Nov 15, 2008 1:19 am
PostPosted: Sat Nov 15, 2008 7:29 pm
Whats the VVT set-up on it? Is it just a cam advancement on the inlet?
PostPosted: Sat Nov 15, 2008 11:13 pm
PostPosted: Sun Nov 16, 2008 11:08 am
