Fiesta-Si.com • View topic - Advice needed
It is currently Thu Mar 26, 2026 9:00 pm
 Post subject: Advice needed
PostPosted: Fri Nov 07, 2008 6:49 pm
Right had a little mishap just now involving a pot hole :cry: and now I get a loud knocking sound when I turn the wheel to full lock also the drivers side driveshaft is realy loose when you pull it, its feels like theres nothing holding it in.
So im after your opinions on what sort of damage has been done
 Post subject: Re: Advice needed
PostPosted: Fri Nov 07, 2008 8:36 pm
you could of damaged ay of the suspension joints, best to check them prorperly for play that will most likely be your knock, cant see why your driveshaft would come loose from hitting a pot hole but you never know! but id startt with checking all sus joints for play and go from there.
http://WWW.S2RS.CO.UK
