Fiesta-Si.com • View topic - fiesta missfires on idle after a while
PostPosted: Wed Oct 15, 2008 12:01 pm
when i leave my ca rto idle for a while and then go to rev it it hesitates and missfires
but when i leave it to idle for a second its fine only when u leave it for 20 seconds
and when i leave it to idle the car pops through the exhasut but i thinks thats due to the cams what u guys think any ideas
PostPosted: Wed Oct 15, 2008 6:06 pm
I think its the amount of power the beast is unleashing.
PostPosted: Wed Oct 15, 2008 6:09 pm
Be abit hard for most people to help you with the problems as your on a different ecu which has been mapped up, so therefore could be down to that, or many of the mods :)
Maybe the settings for the idle need tweaking?
Does your setup use a idle control valve of any kind?
PostPosted: Wed Oct 15, 2008 9:23 pm
nope it doesn have a IAT either it ticks over on 1100 revs maybe some more tweeking is required me thinks
PostPosted: Thu Oct 16, 2008 10:36 am
That's idling a bit high then, have you checked for any vacuum leaks? Have a look under your coil pack, there's an L shaped hose, only small, which often gets overlooked. I had it on mine where it had a hole in it and was causing idling and misfiring problems. Took me bloody ages to find it :lol:
PostPosted: Thu Oct 16, 2008 4:44 pm
had a look m8 and that pipe is left open becuase the brake servo pipe has been connected to the sandwich plate now :shock:
PostPosted: Thu Oct 16, 2008 5:24 pm
PostPosted: Fri Oct 17, 2008 7:28 am
There we go then :lol:
PostPosted: Fri Oct 17, 2008 8:38 pm
:lolz: Still no figures for the car built and mapped by monkeys.
