Fiesta-Si.com • View topic - Exhaust mounts...
It is currently Thu Mar 26, 2026 7:29 pm
 Post subject: Exhaust mounts...
PostPosted: Wed Oct 08, 2008 8:52 pm
Need to mount my exhaust better... I do not use the crossmember which originally held the CAT due to having the Ashley manifold, and it used to vibrate like a tw*t on the RS with the crossmember
So after modding to get rid of the midbox, I need to weld a bracket to mount onto the midbox hanger..
But has been dangling in the middle so need another place to hang the exhaust.
I have seen some sort of mount from the gearbox which I think was found on the FRST's, which looked tempting to try do.. but also thinking of mounting one to the floorpan somehow where the exhaust bends to go around the fuel tank as my exhausts have always dropped low in that place!
Anyone had experience adding extra mounts? obviously have to use some sort of rubbers tho otherwise it would vibrate inside the car!?
Cheers
 Post subject: Re: Exhaust mounts...
PostPosted: Thu Oct 09, 2008 8:53 am
if you have a look in the guide below ive done for fitting the Ashley manifold ive managed to keep the cross member and just made a basic cradle to support it,
PostPosted: Thu Oct 09, 2008 1:24 pm
