Fiesta-Si.com • View topic - starting problems 1.6 si
 Post subject: starting problems 1.6 si
PostPosted: Thu Oct 02, 2008 11:44 pm
right went out my car other day started up nicely as usual and went for a long drive and then parked up for abit..went to start it and it was jus turning over...the engine was turning over but it wasnt starting..it did it to me at college day before aswell.is there anything i should checked after the crash i had???
ohh and wot is the black box that is under the inner arch on the driversside?
its probably sumthing simple but just wondering if you have any ideas??
anything would be helpful :thumbsup:
RuLeThEbEnDs
PostPosted: Fri Oct 03, 2008 8:46 am
might not be it but have a check of the cps sensor as that might be loose etc.
there was a topic about that black box i think its something to do with the petrol vapours, i'll have a search and see if i can find it :thumbsup:
PostPosted: Fri Oct 03, 2008 1:41 pm
The black box your on about, the one with 2 tubes doing into it? Its a breather tank for the oil if i remember correctly.
PostPosted: Fri Oct 03, 2008 3:03 pm
thanks were is this cps sensor? never herd of that :lol:
and the blackbox i had it off when changin the bumper so dont know if i missed sumthing off it,i know theres wire/pulg that goes into it then a hole :doh: :lol:
RuLeThEbEnDs
PostPosted: Fri Oct 03, 2008 3:12 pm
CPS is here:-
* no need to have the gearbox off to get to it, unless the housing has come loose, then its a gearbox/flywheel/clutch off job!!
if you still have your EGR it'll be behind that and just behind the starter motor...its a pig to get to with the EGR still on btw :cry:
PostPosted: Sat Oct 04, 2008 11:33 am
i assume you've checked the fuel cut off switch. It's in the passenger foot well.
