Fiesta-Si.com • View topic - 2.0 zetec problems.
 Post subject: 2.0 zetec problems.
PostPosted: Sat Sep 06, 2008 8:32 pm
hey,
this engine isnt in a fiesta, but id imagine it to be the same, but my escort with the 2.0 has a few problems...
before we start, its a 2.0 zetec, full 2.0 managment (ECU, MAF, Injectors, Fuel rail)
there seems a wierd flat spot at 2k, its recently had new spark plugs, and new HT leads... they have both done about 2.5k, also I cleaned the MAF around 2k ago aswell...
this flat spot seems to be more prominent when its under load, say 3rd gear uphill 35mph.
also, it seems to have its good days and bad days... some days it goes like hell, picks up really well, and then others.. theres no go in it at all, feels like im back with my 1.6.
also..again lol, when I first had the engine fitted, I was running it with the 1.6 ecu, injectors and MAF, and it seemed to go alot better then than it does now. it feels quicker, but theres little things that make me think it was faster back then.
im kinda hoping someone has had a simular experience and they know what could possibly be the problem.
Thanks.
Msn - ryan@areyouserios.com
 Post subject: Re: 2.0 zetec problems.
PostPosted: Sat Sep 06, 2008 8:43 pm
im possibly having a similar problem, unlikely but perhaps. Only a 1.6 but very much has good days and bad days. Ive been directed towards a new fuel pump, or that my cat is dying.
PostPosted: Sat Sep 06, 2008 8:45 pm
ive had a new fuel pump not long ago... it wasnt a new one but it was a working one from another car, so i dont think thats the problem. as soon as i can find another downpipe im having a decat made up, but i dont think my problems stem from that.
keep me updated with how yours goes mate :)
PostPosted: Sat Sep 06, 2008 8:55 pm
how's your car feel when its hot, compared to when its cold?
PostPosted: Sat Sep 06, 2008 9:01 pm
it feels quicker when its cold, but still feels like its holding back slightly.
PostPosted: Sat Sep 06, 2008 9:16 pm
sounds like your issue is pretty much the same as jason's!
have you tried it with another temp sensor or air temp sensor?
have you stuck it on a diagnostic machine?
PostPosted: Sat Sep 06, 2008 9:20 pm
i havent put it on a diagnostics machine, as the local place wants £50 just to diagnose the problem, and i dont have that at the moment... plus i dont wanna spend that lol.
i havent tried either of the temp sensors, but its funny you should mention that as my temp gauge doesnt work... goes all the way into the red when i put the ignition on, and then when i start the car it goes off.
also, its using rediculous amounts of fuel, the other week it cut out after 35 miles to £10 worth of fuel.... my mates m3 evo does that lol.
PostPosted: Sat Sep 06, 2008 9:27 pm
ouch thats a little steep! :cry:
if the escort is like the fez there'll be 2 sensors on the thermostat, top one is the ecu temp, bottom one is the temp gauge
iirc if the temp sensor is knackered it makes run rich
you tried a new lambda sensor on the fuel consumption issue?
PostPosted: Sat Sep 06, 2008 9:32 pm
was told about the lambda sensor a few times now, gonna take it off tomorrow and give it a clean... if i can... ill look into it.
i took it to a local guy who does diagnostics via his laptop, and he wouldnt go any further because the diagnostic machine said it was a mondeo... he wouldnt beleive me when i said it was a mondeo ecu, he thought his machinery was playing up :lol:
PostPosted: Sat Sep 06, 2008 9:51 pm
not sure if they can be cleaned or not, but worth a try :thumbsup: , if not get a replacement :D
bet he was scratching his head for a while :lolz:
is your timing ok?
PostPosted: Sat Sep 06, 2008 9:53 pm
i think it is, a cambelt tensioner collapsed a while ago, luckily nothing got bent, it had only skipped a tooth or 2, but he had problems redoing the timing, couldnt get it right, but he eventually sorted it. it was doing this before that aswell.
PostPosted: Sat Sep 06, 2008 10:01 pm
i'd try the above sensors and see if they make any difference, try them from a known working car if you can or known to off a working car, saves having buy them and find they have done swwweeet fa :lol:
have you tried a different maf other than cleaning yours?
PostPosted: Sat Sep 06, 2008 10:08 pm
well, when we first fitted the maf, it had been in jasons shed for god knows how long, so we fitted it and i took it out for a spin and could barely beat a zetec-s, but then i got it home and i cleaned it and it made loads of difference... i may try one from a different car tho.
someone said somthing to me about a vacuum leak, recon that could be causing anything?
PostPosted: Sat Sep 06, 2008 10:11 pm
really not sure on that, i thought vacuum leaks caused erratic idling? eg. hunting etc
PostPosted: Sat Sep 06, 2008 10:43 pm
Its to low down the Rev range to be MAF, useully around the 3.5k mark.
Check the Gapping on the plugs! :)
And get a Decat while your at it! :thumbsup:
PostPosted: Wed Sep 10, 2008 11:37 am
TPS(throttle position switch)
anyone remember mine on the rollers, sounds like the exact same problem. bad mis/flatspot at 2-2.5k rpm.
