Fiesta-Si.com • View topic - gear box
 Post subject: gear box
PostPosted: Mon Sep 01, 2008 7:08 pm
Hi
I have been told to get a fiesta Si 1800 BC type gear box, higher fist gear and a more suitable
final drive
got one from a scrap yard, they said this is an 1800.
using a spare clutch plate and tipex marks i get about three point eight revolutions to one on the
drive shafts. this may well be a Si 1800 box but how do i prove it
before i have it renovated, new seals etc,
can any one help with any data about the gears and final drive ratios,
or any ID marks.
thanks
andy
 Post subject: Re: gear box
PostPosted: Mon Sep 01, 2008 9:47 pm
I havent got the number with me now, but next time I am down the yard I can check my RS1800 for the number.
Not got exact ratio's but all I can say is that it'll do more top end than an si box (eg. end of clocks), and you can do 65-70 in second thrashing it
why do you want an rs1800 box anyway? particular reason? if its mpg you want its derv box all the way
PostPosted: Tue Sep 02, 2008 9:54 am
Thanks Happypaul
I have the derv box in at the moment.
its in a "SYLVA Mojo 2".
I am hoping for more responsiveness.
I cant get maximum revs in top, and to get a quick start i have to slip the clutch
then its not bad in the other gears
but i take the point about fuel consumption
it was an Si 1800 I was told to look for. Is it different to a RS 1800
Thanks Andysmac
PostPosted: Tue Sep 02, 2008 9:56 am
they didn't do a Si 1800 ;)
Si's are either 1.4 8v's or 1.6 16v zetec's the only 2 1800 fiesta's are the 1.8 16v xr2i and the rs1800 :thumbsup:
PostPosted: Tue Sep 02, 2008 10:47 am
PostPosted: Tue Sep 02, 2008 10:58 pm
Thank you Lads for your help and advice
andysmac
PostPosted: Tue Sep 02, 2008 11:04 pm
PostPosted: Thu Sep 04, 2008 9:48 am
PostPosted: Thu Sep 04, 2008 9:51 am
PostPosted: Thu Sep 04, 2008 9:53 am
i owned/occasionally drive one :hsugh:
PostPosted: Thu Sep 04, 2008 2:02 pm
u can get escort si's in a 1.8, not sure if the box will fit tho?
PostPosted: Thu Sep 04, 2008 2:07 pm
i think they will fit in a fez if its got a front mounted starter motor
what exactly is this gearbox going into?
edit:-
SYLVA Mojo 2 = http://www.sylva.co.uk/ is it that?
PostPosted: Thu Sep 04, 2008 9:32 pm
It seams i was given mixed and wrong advice, sorry boys.
I went down to swanley in Kent this mourning and saw a chap named
Phil stewart a gear box repair and rebuild guy. very helpful
He showed me the empty casing/bell housing of the box i need its the older BC Type.
looking into the box from the engine there is a two inch +- round piece of casting at
about 8 o'clock. below the splined clutch shaft.
the correct box for me has a small core type plug inside this 2 inch casting, 5p size
also the casing around the bottom, below the speedo take off is larger and square.
I dont have any numbers or any thing to explain it, I will have to see for myself.
I am waiting to look at a RS 1800, when the engine comes out, this may be a candidate.
My Car is a Mojo 2 with a Vulcan 1600 CVH on Jenvey's and an Emerald ECU. derv gear box
5th gear is about 80 mph @ 3000 rpm a little to high, but good MPG
About 120 bhp at the moment, most other bits bits are from my old XR2.
regards andysmac
