Fiesta-Si.com • View topic - lowering si'z
It is currently Fri Mar 13, 2026 1:04 pm
 Post subject: lowering si'z
PostPosted: Mon Aug 25, 2008 3:34 pm
i have lowerd my si 50mm and it seemz 2 be alot more low on the front than the back (from weight of engine i guess) but with other cars i dont really see this happen, does anyone know off ne tips to make the back level??
 Post subject: Re: lowering si'z
PostPosted: Mon Aug 25, 2008 4:06 pm
mines about 50mm and is much lower at the front. Doesnt have anything in the back so makes sense, surely the more you lower the back, the more undesteer youll induce?
PostPosted: Mon Aug 25, 2008 4:10 pm
mines 60mm and is the same, coilovers will sort it as you can adjust it so it sits level, i don't recommend cut springs tho they seem dodgy imo
PostPosted: Mon Aug 25, 2008 4:33 pm
FWD are typically like that, it's better for handling to have the front lower.
PostPosted: Mon Aug 25, 2008 7:55 pm
damn scotty beat me
traction also (not that you need a great deal)..
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Mon Aug 25, 2008 8:27 pm
Explain why most FWD cars are level instead of rear higher?
My RS handled fine with rear end level with front.
But to go with the original question, springs and lowering kits are always lower on the front on the fiestas.
PostPosted: Mon Aug 25, 2008 11:08 pm
ive noticed that they r always lower on the front than the bk!!
PostPosted: Tue Aug 26, 2008 9:27 am
Its all to do with the rebound strength
PostPosted: Tue Aug 26, 2008 5:10 pm
PostPosted: Tue Aug 26, 2008 5:44 pm
my mk2 use to sit lower at the rear but most mk2's i have seen do, but my si has always been higher at the back
PostPosted: Tue Aug 26, 2008 6:50 pm
... wel if itz beta 4 handlin dat way . . . den im keepin it lyk it ;)
