Fiesta-Si.com • View topic - Turned out to be a 96 1.8 vectra lol, known problems?
PostPosted: Wed Aug 20, 2008 10:43 am
As title?
Anyone know anything to look for?
i am picking one up for free ;) on saturday for my dad whos in france of his mate.
needsa bit of work, which i will find out :)
just want to know of any known problems :)
PostPosted: Wed Aug 20, 2008 10:51 am
What spec?
Hatch/saloon/estate?
Which engine? 8v/16v? Diesel??
So many questions :lol:
99 will make it a Vectra B. The Cavalier replacement which ran from '95-'01
Thank you pleashe :insanity:
PostPosted: Wed Aug 20, 2008 10:53 am
ooh that may help
2.0 16v
Petrol
Hatch i believe
Spec no idea :lol: lets say Mid spec
PostPosted: Wed Aug 20, 2008 11:14 am
Now the reason small vauxhalls (coras/astras) are worse than their Ford counterparts is because they aren't bolted together by fritz; unlike the Omegas which then have a the Opel badge replaced with a Vauxhall one as their packed onto the ferry.
The Cavs/Vectras cover the confussing middle ground :doh:
A V6 guaranties its been bolted together in the Fatherland by fritz.
90% of the 4-pots were bolted together over here (not good :doh: )
Either way, watchout for electrical gremlins (all easy fixes if you know what your doing, but can be daunting at first) Mid-spec GLS will probably have a couple of faults. Watch trip computer which will often throw a wobbely!
Watch for rust around the arch lips, door bottoms, and under the side windows (YES!! Even on a 99 plate :rolleyes: )
Interiors are solid, if a little squicky if of Blighty origin.
Engines are also solid, if again cursed with silly little gremlins which are easily fixed.
PostPosted: Wed Aug 20, 2008 11:19 am
thankyou kind sir
rust eh, i dont tihnk i will complain to much as it is free :lol:
as long as it can get through an mot its fine
will the 2.0 move? or struggle like the 1.8 lol
PostPosted: Wed Aug 20, 2008 11:29 am
There are 2 1.8s ;)
One is coniserably better than the other, derived from a completely different engine
The 2.0 has a sufficient 135 bhp there or thereabouts, with a book 0-62 figure off sub 9 and a half seconds
Whats up with this one then...define "needs a bitta work"? :lol:
PostPosted: Wed Aug 20, 2008 11:44 am
ah thats nice then 8-)
and honestly no idea, :lol: , its my dads best mate so i don't think he would stitch him up,and a garage quoted £150 to fix whatever it is so i don't think its terminal :? :lol: :hsugh:
PostPosted: Wed Aug 20, 2008 11:59 am
Bet the exhuast is blowing like a barstard.
Just my guess based on the age, and the quoted fix
PostPosted: Wed Aug 20, 2008 12:11 pm
Yeah thats what i was thinking, something along those lines :)
PostPosted: Wed Aug 20, 2008 2:52 pm
bottom left manifold studs snap off other bolts come loose cam cover gaskets leak rear trailing arm bushes front top mounts sloppy gear linkage waterpumps fall off causing valve to piston dammage arb links
PostPosted: Wed Aug 20, 2008 3:05 pm
blimey! :rolleyes: :cry:
lets hope this ones ok :lol:
PostPosted: Wed Aug 20, 2008 3:16 pm
Not on the 2.0 Vectra B im afraid ;)
...with the exception of the top-mounts, but thats quite rare and caused by bigger problems with the shocks, mainly associated with early V6s :thumbsup:
PostPosted: Wed Aug 20, 2008 3:19 pm
messing with my head :cry:
i've been told cambelts are prone to snapping
any truth?
PostPosted: Wed Aug 20, 2008 3:24 pm
Only on the very early X20XE"V"s
......and only because there service interval is relatively short, which isn't ideal when so many people are stupid :doh:
PostPosted: Wed Aug 20, 2008 3:27 pm
ah ok thanks for the help peeps 8-) :thumbsup:
PostPosted: Sat Aug 23, 2008 3:28 pm
the eco tecs r rubbish engines use to have to work on them :lol: if its free i 'd get it and weigh it in £200 sorted :) :lolz:
PostPosted: Sun Aug 24, 2008 10:13 am
na its for my dad,
and its turned out to be a 1996 1.8 vectra
around 120k
Probs:
1 engine management light is on, but unaffected until you hit 4500rpm, they think its a sensor but i duno!
2 small water leak. like a pin prick as it only happens when the system is pressurized, but it leaks into the car. Heater matrix?
3 central locking on passenger front door has to be manually pushed down but no biggy.
4 Slack Gearlinkage, but for a 12 year old 120k motor aint fussed!
few scrapes and dents, taxed till the end of november plus a tenners petrol and the car was free!
PostPosted: Tue Aug 26, 2008 10:03 am
PostPosted: Tue Aug 26, 2008 10:17 am
She be a 1.8 LS with 4 speed fan and cassette player :lol:
Few other niggles i have noticed:
The mileage digital thingy isn;t illuminated :?
the temperature display/radio and clock has some leds out
Handbrake is utter turd :lol:
But it was free :D
Well when you hit 4500rpm, its like hitting the rev limiter! And apprantly it stalls every now and again but it didnt happen to me
Honestly, no idea on the leak, didn't smel anything on the way home, it just generally smells :lol: and the car steams up easily
I'll tell my dad about that, thanks (central locking)
Yeah hopefully one of my mechanic friends (rob :lol: ) can sort this for me.
Its not the greatest car ever by a long shot, but it's quiet, long geared, easy to drive, roomy, free lol only complaints are underpowered and heavy, so fuel consumption isn't great but its my first proper vauxhall experience. I might even give it a clean and whack some pics up on here :lol: 8-)
