Fiesta-Si.com • View topic - Moving drive shaft!
 Post subject: Moving drive shaft!
PostPosted: Mon Aug 18, 2008 7:41 pm
My O/S drive shaft has about 2inch play in it! It moves backwards n forwards from the gearbox in to the rubber thing whatever that is. Also the wheel moves about quite a bit in every direction!? Is this the wheel bearing thats knackered? I took off wheel, caliper and disc and there doesnt seem anything else left to take off! Cant find no wheel bearing, where are they!? Can anyone help pls?
 Post subject: Re: Moving drive shaft!
PostPosted: Mon Aug 18, 2008 7:52 pm
I dont know much about the shafts but if the shaft isnt locating and staying inside the gearbox then you need a new circlip on the end that holds it in the box.
PostPosted: Mon Aug 18, 2008 8:03 pm
thanks for that. yer tis very loose, doesnt come right out the box though. What wud explain the movement at the other end? Jus had a look and the round bit the brake disc is attached to moves about loads!
PostPosted: Tue Aug 19, 2008 12:24 am
so the wheel bearing is shagged in the hub?
PostPosted: Tue Aug 19, 2008 8:28 am
that what I was thinking, but how do you get the wheel bearing out?
PostPosted: Tue Aug 19, 2008 1:57 pm
there is a big nut in the middle, either 30 or 32mm depending.. as some are either.
once you take that off you can get the bearing out
