Fiesta-Si.com • View topic - Steering problem
 Post subject: Steering problem
PostPosted: Tue Aug 12, 2008 6:23 pm
My 2i 8v has loads of play in the steering wheel, as in, if im driving i can turn the steering wheel left and right quite a bit before it actually starts turning! And the steering wheel feels very light in the 'play' area until the wheels actually start to turn. I was thinking steering rack, but it only had one of these a few years ago?
 Post subject: Re: Steering problem
PostPosted: Tue Aug 12, 2008 7:35 pm
Checked for play in ball joints?
PostPosted: Tue Aug 12, 2008 8:24 pm
no and I dont know how to check either! :?
PostPosted: Tue Aug 12, 2008 9:46 pm
may sound silly but have you checked if the steering wheel is tight had same problem after last track day and the nut holding the steering wheel on hade come loose! if not start from the steering wheel and work down the steering column joints to rack and then track rod ends by moving the steering wheel and looking for slack movement
PostPosted: Tue Aug 12, 2008 9:52 pm
could be the steering uj (union joint), that connects the steering rack to the steering column
PM if u want u advert here :D
PostPosted: Wed Aug 13, 2008 7:36 am
usually this happenes when the clamp bolt in the lower uj comes loose try that
PostPosted: Wed Aug 13, 2008 4:08 pm
i reacon its dead wishbones
PostPosted: Wed Aug 13, 2008 4:15 pm
how do i check for wishbones? Jack up car and see if front wheels rock back and forward?
PostPosted: Wed Aug 13, 2008 7:24 pm
look at the bushes see if theyre split
PostPosted: Thu Aug 14, 2008 9:26 pm
well jus took off the union joint n i think its knackered to say the least! there is loads of play in it, looks like its about to snap soon. Still wonder if this small part can cause so much play in steering wheel? Also front O/S wheel rocks about LOADS in every direction so i reckon the bearings have gone on this as lower arm doesnt look so bad. N/S wheel is fine, no movement at all.
