Fiesta-Si.com • View topic - Ashley manifold
It is currently Fri Mar 27, 2026 7:01 am
 Post subject: Ashley manifold
PostPosted: Sun Aug 10, 2008 7:56 pm
Thinking about getting a ashley 4-2-1 manifold for my 2.0 si and theres a couple of things im not sure on
1: Does it come with a hole for the lambda probe?
2: Where does the 2-1 pipe fit, does it fit onto the cat or does it replace the cat and fit to the centre pipe?
thanks
Doug
 Post subject: Re: Ashley manifold
PostPosted: Sun Aug 10, 2008 8:46 pm
PostPosted: Mon Aug 11, 2008 5:11 pm
ive recently fitted a Ashley manifold to my 2Litre and it was not a straight fit, first problem i had was with starter as mine was the longer one so manifold wouldnt fit, when i spoke to Ashley they said they do do a different one with the downpipe further accross but it was to late by then! I will upload my installation to the Guide section in a mo. hope its of help.
PostPosted: Mon Aug 11, 2008 5:31 pm
Thanks guys
I think might the same problem with the starter motor as my current one is about an inch away from the standard manifold and is always getting cooked and not working properly which has caused a few embarressments.
Also I forgot to ask aswell once fitted did you have any problems with the exhaust hanging down
thanks
Doug
PostPosted: Mon Aug 11, 2008 7:02 pm
PostPosted: Mon Aug 11, 2008 7:16 pm
I just looked at that very good guide 8-)
Shame Ashley can't get thier act together and make a decent manifold. I fitted one to my xr2i was a right pain :x
