Fiesta-Si.com • View topic - my car cuts out... any thoughts
PostPosted: Wed Aug 06, 2008 11:26 pm
my car cuts out... i tohught it was the vss but its not
if i leave the car idling it will idle indefinately
if i go for a drive it will cut out when i brake to a low road speed (hence me thinking it was the vss)
if i unplug the tps the car stalls as it should, if i unplug the maf sod all happens
also if i rev it up then close the throttle while standing still it stalls
i'm thinknig i should try another tps, but not sure thats the fault
"they couldn't hit a cows arse with a banjo" Jam
Area-Six.co.uk, AvoUK.com, Castrol.co.uk, Cobraseats.com, Comp.co.uk, GrahamGoode.com, Goodridge.net, MongooseExhausts.com, OMPracing.it, Pipercross.com, Powerflex.co.uk, Sparco-Tuning.com, Toyo.co.uk
PostPosted: Thu Aug 07, 2008 6:59 pm
Tried cleaning the maf, iscv, tps? Could be any of them really.
PostPosted: Fri Aug 08, 2008 8:47 am
i had this problem when i fitted my 2.0 have you changed the tb at all if so play with the idle screw
PostPosted: Fri Aug 08, 2008 12:21 pm
the car was fine as a 2.0 just had an oil leak so i took it apart to fix that and now its cutting out
will see if i can find another tps to try
PostPosted: Fri Aug 08, 2008 7:04 pm
PostPosted: Sat Aug 09, 2008 7:21 pm
there is an idke screw on the throttle stop ;)
PostPosted: Sun Aug 10, 2008 2:20 pm
oh yes they do :P
PostPosted: Thu Sep 04, 2008 7:46 pm
My car suffers from rolling stalls :P
i'll go to stop at a traffic light and just as i dip the clutch it dies, i get funny looks when i'm starting the engine up still rolling
i think the problem on my car is a combination of
fuel pressure regulator
superchip and
air filter
buttery biscuit boost
PostPosted: Sat Sep 06, 2008 9:37 am
have you checked its not a petrol issue
check the following!
fuel filter isnt choked up
timing
alos the vehicles speed sensor can cause this issue stalling at lights
