Fiesta-Si.com • View topic - passed MOT but is my car running lean from emission readings
PostPosted: Wed Jul 09, 2008 6:40 pm
might be a daft question but the CO reading on me car was 0.00 <0.20%
the HC was 29 <200ppm
the lambda was 1.000 for MOT it has to be between 0.97 - 1.03
natural idle test was
engine speed 450 - 1500 0.43
CO <0.30% AND WAS 0.43
some help would be great cheers
PostPosted: Thu Jul 10, 2008 11:11 pm
If its passed within the limits of the MOT then clearly its okay?
You have a modded car, its not going to be perfect
PostPosted: Fri Jul 11, 2008 6:11 pm
if its a zetec check the vacume pipe that come out of the side of the head down the back of the coilpack, its meant to go to a tube that goes to the crankcase breather. if this has a hole in it it will lean the engine out. if its not zetec then i dont know im afraid, unless its carb'd
http://WWW.S2RS.CO.UK
Users browsing this forum: No registered users and 91 guests
