Fiesta-Si.com • View topic - Whats the plug?
It is currently Fri Mar 27, 2026 9:41 am
 Post subject: Whats the plug?
PostPosted: Mon Jul 07, 2008 8:45 pm
Can anyone tell me what the plug/sensor is under the rubber air inlet hose. I've found a bad case of bodging on the plug and want to know if its important?
 Post subject: Re: Whats the plug?
PostPosted: Mon Jul 07, 2008 8:47 pm
Picture!!!??
PostPosted: Mon Jul 07, 2008 9:12 pm
I can't its under the hose. Its conected to a metal pipe, bout 8/10mm the disappears down the side of the engine.
PostPosted: Mon Jul 07, 2008 10:43 pm
would be nice with a picture even if you cant actually see it just in the general direction with a ring around where it is under the pipe because it could be water temp plug x2 , crank sensor, maf plug, reverse light plug, fan plug lol think theres not a lot else that side of the engine
PostPosted: Fri Jul 11, 2008 8:47 am
sounds to me like power steering fluid pipe.
does it run across the top of the engine near the cam belt cover?
this one?
PostPosted: Fri Jul 11, 2008 10:07 am
i think rotti got a 1.4, to me that sounds like it could be the ISCV plug, although im not totally sure bout that.
