Fiesta-Si.com • View topic - weird suspension problem!
It is currently Fri Mar 27, 2026 7:01 am
PostPosted: Sat Jun 28, 2008 2:46 pm
right i noticed today when i was polishing the car that my passenger side suspension is really really hard!! its like rock hard you cant even push it down. but if you lift the car up then push the suspension down again your able to push the car down but after pushing it down about 10 times it goes rock hard again! its running 35mm gmax shocks and springs. i hit a rather large pot hole last week and im just wondering if this could be a simpton of a knackerd shock altho i have never herd a shock going stiff if its damaged! there is quite an annoying baffled knocking sound aswell now.... the car isnt leaning attal so im clueless on this tbh
any help much appriciated :)
PostPosted: Sat Jun 28, 2008 4:11 pm
maybe its got some grit in it or something :?
PostPosted: Sat Jun 28, 2008 9:50 pm
if the pothole was real big u might have slightly bent the piston pod m8 i dont it on mine whith g-max fitted but it also bent the wheel :(
