Fiesta-Si.com • View topic - miss fire in the 2.0
It is currently Fri Mar 27, 2026 7:01 am
 Post subject: miss fire in the 2.0
PostPosted: Thu Jun 26, 2008 6:32 pm
hi all hope you can help? have just recently fitted a 2.0 engine to my si and all is well untill it started. have sorted a few things out but now but its still missing through the rev range as well as the idle?? have done a compression check and three cylinders are the same and one is abit higher but all in all good compression. the plugs are covered in a black soot if this helps. ive put the 2.0 injectors, air mass, ecu and throttle body on as well as new plugs and a tested set of leads and a tested coil? but dont know what to look at next?? :banghead: :banghead: any sugestions welcome
thanks paul
 Post subject: Re: miss fire in the 2.0
PostPosted: Thu Jun 26, 2008 6:33 pm
what plug's and leads are you using?
PostPosted: Thu Jun 26, 2008 6:50 pm
standard plugs and leads for the 2.0
PostPosted: Thu Jun 26, 2008 7:08 pm
hmmm.. they new?
might sound like a daft Q but,you got all the connectors on in the right place?and air leaks?
PostPosted: Thu Jun 26, 2008 7:47 pm
PostPosted: Fri Jun 27, 2008 6:47 pm
try a coil m8 they are very crappy and work on a benchtest but not on the car worth a go
PostPosted: Sat Jun 28, 2008 6:11 pm
coil was ok it was the 2.0 injectors the spray pattern was abit differant on one of them as i took the fuel rail out and turned the engine over. 3 were fine but the 4th was like a water gun just one straight line and not a spray. the new problem is that when you rev the engine slowly its fine but when the heavy foot gets planted to the floor (as you do :devil: ) it goes straight into a missfire until you let off the gas. my suspision is either the fuel pump or the fuel pressure regulator?? any sugestions welcome
PostPosted: Sat Jun 28, 2008 6:21 pm
try the throttle switxch sounds like its giving the wrong signal or none at full throttle i had the same prob on my 16v mk2 golf
