Fiesta-Si.com • View topic - What i thought was the pump....
It is currently Fri Mar 27, 2026 9:40 am
PostPosted: Sun Jun 15, 2008 8:05 pm
basicaly peeps i need sum advice i bought a fiesta si wid a 2ltr conversion in it half stripped down because basicaly the person who did the conversion put the engine in with wrong water pump so he thought and then couldnt be botherd 2 finish it off so i bought it took waterpump out bought a new water pump frm a 1.6 fiesta si and well the pumps are identical and a friend of mine told me the fins on the pumps shuld be different as one of the pumps should pump the water different .... so the reason for the person thinkin they handnt put right pump had syptons of car overheating and water boiling up... when i took the water pump off the car it was in a bit of a state it was reli rusty n corroded and was leaking slightly but surely this would not cause the car to boil up the water in the fill chamber n blow the cap off?
and ideas would be great cheers...
i was thinking head gasket :|
PostPosted: Sun Jun 15, 2008 8:10 pm
i'm not very technical but water boiling up sound like the HG to me :cry:
or an air lock of some sort?
not sure really
PostPosted: Sun Jun 15, 2008 10:45 pm
Either the pump broke and did the headgasket, or it was wrong pump, or headgasket just went
PostPosted: Mon Jun 16, 2008 9:06 am
ryt ok the only other thing that i remeber now is that the alternator bracket was broke so the alternator was basicaly bien hled up by the belt and if im correct this belt drives the pump to yh? so if there was not enough tension on the belt because the bracket on alternator had snaped wouldnt this stop the pump from working efficently because the belt would be slipping on the pulley?
cheers for youre advice if any one else has any ideas im thinking it is Head Gasket to be honest but i dont wont to go to the trouble of replacing it if its not the problem...
PostPosted: Mon Jun 16, 2008 9:16 am
where abouts on the bracket was it broken?
top bolt or bottom bolting place?
PostPosted: Mon Jun 16, 2008 9:19 am
sounds like the head gasket has gone due to it over heating mate
PostPosted: Mon Jun 16, 2008 9:41 am
PostPosted: Mon Jun 16, 2008 9:51 am
umm.. not sure if the top bolt would do anything, doesn't help though that that bolt is broken :cry: , but its mainly the tensioner pulley that keeps the belt tense
is that done up correctly? and you getting the correct tension on the belt?
i'm not sure on a HG change, just take the head off clean the surface on the head, get head skimmed then put new gasket on, torque bolts up to correct torqure-i-ness :hsugh: :lol:
re-do timing etc
i'm not to technical, but i think thats the just of it, get a haynes manual ;) tis your fiesta bible :teehheee:
PostPosted: Mon Jun 16, 2008 1:59 pm
just to make sure if i take a picture of the new water pump iv got can any 1 tel me if its the correct 1 ?
because i have jus been 2 see a friend who is a mechanic and is telling me the new water pump is the wrong 1?
cheers
PostPosted: Mon Jun 16, 2008 2:01 pm
why did he say it was wrong?
if your using a 1.6 Si or a rs1800/xr2i 16v water pump then your fine
PostPosted: Mon Jun 16, 2008 2:06 pm
well the new pump is off a escort 1.8 si i think? and he said the fins on the pump are going the wrong direction?
PostPosted: Mon Jun 16, 2008 2:16 pm
ah not sure on the escort pump, not sure which way that goes, all i know is fiesta zetec stuff = spins right way and the mondeo pump = spins wrong way
