Fiesta-Si.com • View topic - electric windows xr2i
It is currently Fri Mar 27, 2026 7:01 am
 Post subject: electric windows xr2i
PostPosted: Wed Jun 11, 2008 10:49 am
not so much a problem but i have just fitted eletctric motors for windows and have the switches out of xr2i for centerconsole just wondering how you wire it up
there are 7 pins on the back of each switch i can manage to make it window go up but not down
so if anyone would be able to post me a pic of there switch or explain the order of the wires i would very thankfull
PostPosted: Wed Jun 11, 2008 11:10 am
it would probly be easyer if you got the wireing loom
PostPosted: Wed Jun 11, 2008 1:35 pm
i dont think it will be easier 100 plugs and loose wires
or 5 wires
PostPosted: Wed Jun 11, 2008 7:25 pm
Its alot simpler with the wiring loom, honestly"!
PostPosted: Wed Jun 11, 2008 9:56 pm
so your telling me to put the exr2i cvh loom in a zetec
PostPosted: Wed Jun 11, 2008 10:33 pm
Yes, simply. All you need is the electric window/central locking/boot pop part of the loom, not the completecar loom!
If you want switches in the middle get the loom from a early xr2i. If you want switches in door pockets get one from a later fez.
Both work on same principle
Both have 3 separate parts, 2 door looms and car part of the loom.
Its separate to main loom and incoporates elec windows, central locking, boot pop and the speaker wirings. However when i did mine i just pretended the speaker wiring wasent there and left the original speaker wiring in. (if your just doing leccy windows then the wiring will be there later on for central locking etc)
All you need to do is lay it through the dash and doors, tie it up where needed and connect. If you lucky there might be a plug for all the powers and earths and it will plug straight in. If not, its not the end of the world, just go on fiesta guides.co.uk, look at the wiring diagrams for thre pin out of the power plug.
Then all youve gotta do it connect the earth to the bodywork and the central locking power/window power/boot pop to a live (fused of course)
In fact have a quick browse around fiesta guides its handy.
PostPosted: Thu Jun 12, 2008 12:44 pm
ohh iv just got a loom for it all workin now thanks alot
how much would a set of 14 inch series1 turbo wheels be worth as i just bought some they looking a bit small for the fez
