Fiesta-Si.com • View topic - escort MAF problem
It is currently Fri Mar 27, 2026 8:26 am
 Post subject: escort MAF problem
PostPosted: Thu Jun 05, 2008 6:47 pm
is my sensor duff the car has started to run lumpy the revs are up and down a bit also the revs will go up when i unplug the maf aint the car suppose to cut out also the car revs to bout 3000 on its only when moving when i stop the revs will come down
 Post subject: Re: escort MAF problem
PostPosted: Thu Jun 05, 2008 11:25 pm
do the usual.. clean MAF, ISCV, make sure everythings plugged in
then see
PostPosted: Fri Jun 06, 2008 8:37 am
clean the idle valve sorted the over revving but then engine still likes to run a little lumpy and idles up and down on tickover cleaniung the maf made it a little better but not much so i unplugged it again and the revs went up a little and plugged it back in then came back down any ideas
PostPosted: Mon Jun 09, 2008 3:41 pm
sounds to be the MAF my escort was suffering with simular problems, mines still unplugged and running fine 2 months down the line as a new one was £100 odd down the factors :rolleyes:
might try cleaning it now that thats been mentioned
edit.....
cleaned it and the car goes like a rocket now ;)
