Fiesta-Si.com • View topic - is a 'scort si radiator the same as the FSI radiator?
It is currently Fri Mar 27, 2026 7:02 am
PostPosted: Tue May 27, 2008 9:37 am
believe the engines are the same (or very similar) but is the rad the same?
PM if u want u advert here :D
PostPosted: Tue May 27, 2008 3:10 pm
i would guess so, but even it its a different size, as long as you can securly fit it on the fiesta it will be fine to use 8-)
PostPosted: Tue May 27, 2008 3:26 pm
PostPosted: Tue May 27, 2008 3:33 pm
iirc(going by a brief look at my cousins escort engine bay) one of the temp sensors i think the fan switch one is mounted on the coolant pipe that goes towards the thermostat, so that might be an issue as the fez has its mounted at the drivers side of the rad
worth some investigation ;)
PostPosted: Tue May 27, 2008 3:43 pm
i can have a look at the escorts in me local scrappies but cant find a FSI anywhere (hense why im asking about the 'scort)
this may sound dumb (never stopped me before and its not gona stop me now :lol: ) but could i not fit a temp sender into the 'scort rad, either 1 from the 'scort or a new FSI one? :?
PostPosted: Tue May 27, 2008 5:44 pm
you could do, but i'm not 100% if the 'scot rad is the same as the fsi one, it might have like a blanking plug or such like
check the 'scrt one, get some pic's too ;)
PostPosted: Thu May 29, 2008 7:06 pm
The other day i made my fez one fit my escort but it was hard.
Escort bottom hose points to the side rather than too the engine and mounts totally different. Bit of bodge and make fit and it will work,
PostPosted: Fri May 30, 2008 12:25 pm
PostPosted: Fri May 30, 2008 2:53 pm
Just get a few hoses and cut them up to make one which fits 8-)
PostPosted: Fri May 30, 2008 4:41 pm
yeah i wil, cant get a FSI rad so the escort 1 will have to do, only real prob i can see will be the sensor terry mention'd
PostPosted: Fri May 30, 2008 6:33 pm
