Fiesta-Si.com • View topic - My 2litre Si is Dead
It is currently Fri Mar 27, 2026 7:02 am
 Post subject: My 2litre Si is Dead
PostPosted: Sun May 11, 2008 9:40 pm
Hi im new I recently bought a 2.0 litre Si was driving along and then the engine cuts out and now the car wont start engine turns over but wont fire
I have already check everything I could think of but can't seem to find the cause of the problem any sort of help or ideas would be appreciated thanks
 Post subject: Re: My 2litre Si is Dead
PostPosted: Sun May 11, 2008 9:57 pm
evening
you say you've checked everything you cant think of, does that mean you've checked for a spark?
sounds very similar to what happened to beck_si's car, but after me working on it for a good few hrs i never found the issue and neither did a mechanic as it worked sweet as a nut for him :? :rolleyes:
has it got an immobiliser?
PostPosted: Sun May 11, 2008 10:01 pm
It does have an immobiliser
Whats the best way to check for a spark
It had a slight idle problem when the engine was warm and would drop to 500rpm and sometimes stall
PostPosted: Sun May 11, 2008 10:34 pm
take one of the spark plug's off and hold it near the exhaust manifold and get someone to turn the key as if to try and start it
and check your getting fuel as well, while your at it
the idle problem could be down to your iscv needing a clean
PostPosted: Sun May 11, 2008 10:38 pm
Thanks will check tomorrow
PostPosted: Sun May 11, 2008 11:00 pm
I think there is petrol getting to the engine as you could smell it when trying to start it
Also when the engine went it jolted me forward and rev counter read 0 rpm but I could still hear the engine running and I tried it in different gears wouldn't work and when I pulled over the ignition lights came on as the engine just cut out and I havent been able to get it started since hope this makes some sense
PostPosted: Mon May 12, 2008 8:26 am
have u checked for a spark sounds likie the crank shaft sensor or the coil pack if theres no spark
PostPosted: Mon May 12, 2008 5:14 pm
There is no spark what so ever
also the outside of the plugs were covered in oil where the HT leads attach
still wont start
PostPosted: Mon May 12, 2008 9:33 pm
try replacing your CPS
here's a pic on where it is
then try for a spark again
let us know how you get on
not sure about the oil tho :?
PostPosted: Tue May 13, 2008 8:09 am
Do you know what the part number is for the Crank Postion Sensor
Thanks
PostPosted: Tue May 13, 2008 8:22 am
i dont know the part number off the top of my head, if no one has replied with one by the end of the day i'll try and look on the spares i have to see if they have a number on them ;)
if not try and go to the scrappers and get one or take the one thats on your car out and give it a clean it might have to many metal filings on it so it might be stopping it picking up a signal
PostPosted: Tue May 13, 2008 8:30 am
oil u mean in the spark plug ports if that will be down to the rocker gasket
PostPosted: Tue May 20, 2008 6:29 pm
Car is now running was the multiplug that connects to the coilpack was broken and kept coming loose
