Fiesta-Si.com • View topic - Fiesta needs service
It is currently Fri Mar 27, 2026 7:01 am
 Post subject: Fiesta needs service
PostPosted: Thu May 01, 2008 8:12 pm
anyone got any advice to give on what kind of parts do i need like makes of service parts e.g spark plugs, oil filter... whats the best oil for a fiesta 1.6 si??
 Post subject: Re: Fiesta needs service
PostPosted: Thu May 01, 2008 8:42 pm
Oil - 5w 30 Part Sythetic Oil. Branded, i.e. Castrol works well.
Plugs - from my experience NGK Platinum plugs work, but you are best to get Ford spark plugs from a dealer.
HTs - Only use ford HT leads
Oil & Fuel filter - pattern parts are fine, but you may aswell get from ford also
thats your basic service....
hope this hellps
andy
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Thu May 01, 2008 11:42 pm
as andy said, but also check when the cambelt was last changed :)
PostPosted: Fri May 02, 2008 10:03 pm
Onslack's other half
check your air filter aswell, and if its mashed, go k&n panel, with drilled airbox 8-)
PostPosted: Fri May 02, 2008 10:07 pm
why would you want a drilled airbox....then you just lose the cool air from the CAF you should put in.....and gain warm air :s
PostPosted: Sun May 04, 2008 1:15 pm
thanks guy lol tappet went yesterday so gotta get that sorted now before service lol £200 is cheapest price i got :S lol while i was showing someone that the tappet was knackered the water pump went as well getting it sorted soon as though
PostPosted: Sun May 04, 2008 1:29 pm
Sounds like a service is the least of your worrys ay m8 :rolleyes:
Engine flush, semi-Syn oil, filter, NGK platinum plugs
Coolant flush, engine coolant
Pads if needed(Dont forget pad grease), Re-new brake fluid
