Fiesta-Si.com • View topic - Manifold
It is currently Fri Mar 27, 2026 5:35 am
 Post subject: Manifold
PostPosted: Wed Apr 23, 2008 10:17 am
What 4-2-1 manifold can i get for my 2.0l zetec fiesta? Ive heard about escort and focus ones fitting with little modification? This looks reasonable
http://cgi.ebay.co.uk/OBX-4-1-EXHAUST-H ... otohosting
What have you people got? thanks
2.OL Si, Xr2i Kit, RS Turbo pop outs, Removed EGR, 4-2-1 Ashley Manifold/ Decat, Air Filter, RS Turbo LSD Gearbox With Uprated Pinion Shaft Bearing, 16" Mondy Wheels in Anthricite, Custom Paint, V6 Mondy Brakes, Smoked Rear Lights, Momo Snap Off Steering Wheel, Pager Alarm, 12" Alpine Phase 2 Sub Specially Ported Box JVC DVD Head Unit the list goes on blady blady blah
Coming Soon GSXR1000 Tb's and Megasquirt :devil:
 Post subject: Re: Manifold
PostPosted: Wed Apr 23, 2008 11:35 am
looks very cheap yea for what ur getting but i would get a ashley one much better make ect also they ARE dyno prooven
PostPosted: Wed Apr 23, 2008 12:03 pm
Search for members Views on the ashley manifold, but you can sum it up with, you get what you pay for, cheap does the job, but there are better out there, its Mild steal so will rot unlike stainless! :)
Ask Happypaul on his views he has one and ask Des as the Manifold was designed on his Si! :)
PostPosted: Wed Apr 23, 2008 6:27 pm
looks good, but would think as it rises up first that clearance would be a problem and increased under bonnet temperature, 1 thing to look out for is i think some Zetec escort manifolds will not fit as the down pipe hits the starter motor
PostPosted: Wed Apr 23, 2008 10:28 pm
The focus one will fit with modifiction, but its feking tight! Like seriously tight between down pipe and starter motor!
DALSY got one on his IIRC.
Im getting an ashley one end of this month, gotta be better than a standard fez one at the least.
PostPosted: Fri Apr 25, 2008 7:27 pm
Yea i think ive seen 1 bein fitted and they hadto persuade the part closest to starter by dinting it in a little with a hammer lol. So would you say an ashley would be better? Im just using the 1600 one and it must be holding me back quite a bit.
PostPosted: Fri Apr 25, 2008 10:01 pm
ashley ones are a pain the arse.
you have to remove the starter (or was it alternator) to get it into the bay. or do what I did and completely bend the front panel to get it in.
its tight around the starter
you will have to remove one of the hangers for the cat which is on that S brace thing. and most likely add some more pipe to it to fit the rest of your exhaust, around 2inch worth, so best be handy with a welder to get it done properly.
also it will sit on the S brace unless you have fitted an extra hanger to the actual manifold where it turns 2 into 1, FRST's have hangers from the gearbox, so maybe possible to fit one there, or try make one to incorperate that S brace.
just warning you before you think its an easy off and on job.
PostPosted: Sat Apr 26, 2008 5:10 pm
F***inghell was about to order one of these on monday :x i might just buy it then take it to a exhaust specialist to do me a full system? But then id have to drive it there with just the manifold?? Has everyone got to do this?? thanks
PostPosted: Sun Apr 27, 2008 3:18 am
PostPosted: Sun Apr 27, 2008 9:35 am
So does it come with like a de-cat already?? thanks :?
PostPosted: Sun Apr 27, 2008 11:52 am
PostPosted: Sun Apr 27, 2008 3:05 pm
what the hell were you doing paul you animal :lol: :lol: ...my ashley one went in with the removal of the starter..it will go in with the rad in place but i took it out for safety... imo..ive fitted worse things than that! yes the lower s shaped brace has to come off and youll have to make a front hanger but otherwise its not that bad..imo
can i just add one point. for all those of you who slate mild steel manifolds its down to the quality of the steel. another car i own has tubular mild steel manifolds on that are getting on for 20 odd years old....yes they are a bit brown..but no where near rotten through granted ashelys are made from thinner steel but i should imagine by the time it rots through the rest of the car will have long been put in the bin. thats just my tuppence 'apennys worth.
ashely manifolds also have a history of splitting when heat wrapped..dont know why or if its been resolved but this has been the word on the grapevine for some time
Jam
PostPosted: Mon Apr 28, 2008 7:46 am
So you didn't have to do no choppy choppy? lol I was also going to heat wrap it maybe ill have a double think about that :shock: ?
PostPosted: Mon Apr 28, 2008 4:23 pm
you had to do some addy addy.
although mines just f*cking came off the manifold again, so just drove 20 miles from work with just the manifold. awsome, f*cking exhausts
no fault of the ashley, just the bloody clamps
PostPosted: Mon Apr 28, 2008 6:50 pm
i dont know weather to buy one now? But whatever i buy im going to have to modyfy it to fit anyways :( going to do some cryi cryi now lol :frown:
PostPosted: Mon Apr 28, 2008 10:41 pm
You could clamp some pipe onto it, not too hard really.
I've found the problem of mine, the rest of the exhaust wasnt sat correct and pulled the 2-1 bit of the manifold off lol, gonna sort it once i get my extra stainless pipe ready to remove my mid box ;)
PostPosted: Tue Apr 29, 2008 7:36 am
Ah ill just buy it then hope for the best lol.
PostPosted: Wed Apr 30, 2008 12:07 am
Onslack's other half
'tis what everyone says just before they buy a ford :lol:
PostPosted: Wed Apr 30, 2008 6:17 pm
I didnt, I thought f*ck me thats cheap, Ta.
Users browsing this forum: No registered users and 84 guests
