Fiesta-Si.com • View topic - clutch adjusting arggg
 Post subject: clutch adjusting arggg
PostPosted: Tue Apr 22, 2008 7:43 pm
:devil: im getting really pissed of because at the weekend i fitted a new clutch cable cuz it was really stiff and slipping now the pedal is up in the air and dont know how to adjust it plz help i need a simple guide with pics soon as plz
PostPosted: Tue Apr 22, 2008 9:57 pm
is it the automatic adjuster? if so have you tried getting your foot under the peddel and lifting it fully up, this normally lifts the automatic adjuster and will release the cable. you can then push the peddle down a couple of time to let the cable re-adjust automatically.
hope it works
PostPosted: Tue Apr 22, 2008 10:53 pm
its got the white screw thing help please
PostPosted: Tue Apr 22, 2008 11:04 pm
you can unscrew it and push it in to release the self adjusted once the cable is connected then lift the pedal to the right high and screw it back in
PostPosted: Tue Apr 22, 2008 11:10 pm
ok so if i take it off at the box end then undo the white screw thing push it in (white screw thing) will pedal fall to floor ? then do up screw reconnect cable and manually lift pedal to correct height yes
PostPosted: Wed Apr 23, 2008 11:33 am
i dont it yay
gunna make a guide now for others cuz im nice like that :lol:
