Fiesta-Si.com • View topic - lowering my car
 Post subject: lowering my car
PostPosted: Mon Apr 21, 2008 9:58 pm
hi i have just lowered my si, i bought a set of gmax 30mm lowering kit off alexgotaSI,
but the problem is that the front wheels sit very low that they are slightly inside my arch and any bump or tight corning it rubs plus my cat is about 3 inches off the floor so speed bump are a no no, , i have looked at the spring the its all in the right place and it has gmax 30mm stamped on it, i know it should not be that low its like i have fitted a 60mm kit from the amount of drop,
could it be that the spring has had it , the shocks were fine when i put them on and pressed in with pressure and came out on there own
any ideas would be good, thanks
 Post subject: Re: lowering my car
PostPosted: Mon Apr 21, 2008 10:05 pm
type in the code to gmax website or potn.com
Sounds like a 60mm kit... after being in moes old fiesta :lol:
Hope that helps :)
PostPosted: Mon Apr 21, 2008 10:07 pm
yeah but why has the springs got 30mm stamped on them, the rear is fine
PostPosted: Mon Apr 21, 2008 10:10 pm
pay no attention to the numbers... moes old ones said 30 in the code and he looked it up on the website to check if the were 60mm which they were...
PostPosted: Mon Apr 21, 2008 10:11 pm
oh nice so he sold me 30mm knowing that they are 60mm springs in the front,
PostPosted: Mon Apr 21, 2008 10:13 pm
http://www.potn.co.uk/p1250148.htm This is the pre 94 kit
http://www.potn.co.uk/p1250150.htm Thats the si kit
Heres a link to the 60mm code. check the code before you go making assumptions :)
PostPosted: Mon Apr 21, 2008 10:17 pm
ok i check the codes tomorrow, it may look like i have to order new springs
PostPosted: Mon Apr 21, 2008 11:49 pm
The height from the floor also depends on what size wheels you've got, I've got a gmax -35mm and 14 inch wheels and can't even get a trolly jack under the chassis rails if I want to jack it up!!
Tied
PostPosted: Mon Apr 21, 2008 11:55 pm
The springs could have lost tension with age, you got a 2.0? they also weight the front down more, could be other worn components too.
PostPosted: Tue Apr 22, 2008 12:13 am
The rear end of a fiesta always seems to sit high with gmax springs on.
Look at my car, I have 35mm fronts, with 60mm rears, just to level it out a little more (I cant use 60mm front due to size of wheels lol)
The numbers on the springs as said above do not correspond to the actual mm of lowerage they give, I think my 60mm's say 30 on them, its a part number so check ;)
PostPosted: Tue Apr 22, 2008 1:26 am
stick with 60mm........slammed is good 8-)
PostPosted: Tue Apr 22, 2008 1:52 am
PostPosted: Tue Apr 22, 2008 7:09 pm
just checked the code on the spring and they are normal mk3 fiesta/van 60mm springs.
i have 14" wheels and it rubs on bumps and hard turns so i would changing my tyres every week because they will have a big groove in them!!!
so i have just ordered 30 mm springs kit for a fiesta si,/ rs, xr2i 94-95 which should lift it up a bit. and look more level and stop so much rubbing
so now the old ones are for sale, 30mm rears and 60mm front springs, which puts the tyre just inside the arch, looks good from the front but not good for me to many speed humps around, would be better if you have 13" wheels so it may stop the rubbing.
PostPosted: Tue Apr 22, 2008 8:14 pm
depends on the wheel size and ofset
as I could use 15 inch alloys perfectly with a 60mm drop, and that using standard mk3 (not 3.5) springs, I could have used my 16's if I run 195 tyres, but I run 205's
PostPosted: Fri Apr 25, 2008 11:48 am
all sorted , i bought some 30mm springs for the si, i have only changed the front but it looks level so i may have 60mm springs in the rear as well, i dont mind it looks better level.
thanks for your all your help
PS, thanks to the person, for selling me the kit with 60mm springs, knowing they are 60mm spring and telling me that they are 30's, cost me alot of time plus i has to but new springs
what ,such a nice fiesta si owner he is, thanks,
PostPosted: Fri Apr 25, 2008 12:00 pm
The Nude Numpty
The Nude Numpty
Did he definatly know they were 60mms? Either way if I was you Id ask for my money back, as something was sold with a description, and the goods didnt match that.
PostPosted: Sat Apr 26, 2008 12:02 pm
i have pm him and had nothing back, he fitted them to his car but then did not want them because, he then changed to spax suspention, so he saw how low they were, plus a friend of his said it a post above that he has a problem, and when he checked to codes on the spring to the website he found they were 60mm not 30mm,
nice bloke,
PostPosted: Mon Apr 28, 2008 3:54 am
jus bin reading the post an yea i had a few problems lowering my fiesta, i went out an bought a 60mm cobra lowering kit an fitted it with the standared 14inch si ally wheels the front seemed to be fine was really close as i couldent fit my little finger between the wheel an the arch but dident rub or scrub as the springs are so solid they wont even compress lol but the back seemed to be up in the air an bounce like nethin, so the way i solved it was to remove the lowering springs from the back an put the original ford springs back on but just minus 4 coiles with the handy angle grinder lol an now it handles and looks fine just the look i wanted, however if anyone is thinkin about cutting the spring to lower a car bear in mind it is very dangerous an i would strongly advise not cutting front coiles as is more dangerouse than doin the back, it will also fail an mot, but it seems to me tho that it realy is pot luck when buying a lowering kit as you never realy no how your car will sit untill its back on its wheels.
