Fiesta-Si.com • View topic - Indicator Problem
It is currently Sat Mar 14, 2026 5:29 am
 Post subject: Indicator Problem
PostPosted: Fri Apr 18, 2008 3:17 pm
i have started to have a problem with my indicators,
when i indicate the lights stay on, very delayed tick, (if that makes sense)
its been happening for a couple of days now, and desperately need to sort it out..
is it an easy job?
what do i need to do?
Help Me Pleaseee
 Post subject: Re: Indicator Problem
PostPosted: Fri Apr 18, 2008 3:33 pm
I had this problem numerous times, once it was due to the battery not being connected properly, another was a blown bulb and the other time was a problem with the indicator stalk, so changed that and it seemed okay.
Hope that helps :)
PostPosted: Fri Apr 18, 2008 3:39 pm
my boyfriend said something about the idicator stalk, did u just get a new one or fiddle with it? might try re-connecting the battery.
i thought that if your idicators ticked too quickly that meant the bulb had gone? or is it both ways? cos my hazards are the same they just stay on.
feel like such an idiot wen i have to indicate. haha
PostPosted: Fri Apr 18, 2008 3:44 pm
Yeah i was the same, all the dirty looks people give you for not indicating!
I just changed the stalk, but honestly my car has issues with its electrics! Im pretty sure once it was my headlamp bulb that had gone that was setting everything to awol!
Try checking all the bulbs, and then changing the stalk.. they are about £15 from a scrappy i believe.
PostPosted: Sun Apr 20, 2008 2:09 pm
Most likely just the relay. Jus take of bottom part of plastic covering, take old one out and pop a new one in.
