Fiesta-Si.com • View topic - my 2.0ltr si is spittin oil out from the cam cover breather?
PostPosted: Tue Apr 01, 2008 2:07 pm
hey people luckly iv got the day off to day finaly got my car back after i smashed my si box to bits and now this , give the car a bit of stick nothing more than normal and then.... smoke and lots off it , got home opened the bonnit and theres oil everywere? it seems the breather pipe had come out the air filter and just chucked oil over the hole bay ? now things i think it could be ?
valve steam sills?
pistion rings ( hope not havnt got time to replace them :( )
breather in the front of the block is blocked or not working?
i will remove the down pipe and the breather when the cars cooled down but anything else i should check
many thanks ..... :cry: :cry:
PostPosted: Tue Apr 01, 2008 3:02 pm
sounds like you have alot of pressure in there but first off clean out everything to do with the breather ( hoses and any collector pots etc ), that is normaly the cause for things popping off !
PostPosted: Tue Apr 01, 2008 3:34 pm
thats a blocked breather m8 u checked the crank case Breather valve located under the manifold
PostPosted: Tue Apr 01, 2008 5:17 pm
update yeah its that valve is fucked mates bring one round later to replace it thanks
