Fiesta-Si.com • View topic - too much oil.
It is currently Fri Mar 27, 2026 5:35 am
 Post subject: too much oil.
PostPosted: Fri Mar 07, 2008 9:50 pm
PostPosted: Fri Mar 07, 2008 9:53 pm
PostPosted: Fri Mar 07, 2008 9:59 pm
PostPosted: Fri Mar 07, 2008 10:10 pm
Tied
PostPosted: Sat Mar 08, 2008 12:14 am
PostPosted: Sat Mar 08, 2008 2:15 am
PostPosted: Sat Mar 08, 2008 1:54 pm
mine over filled once my 1.1 fiesta and i found that the oil filelr cap kept blwoing off and there use to be a rumbling noise which was due to oil pressure build up id take the car back and tell them to take the overfilled oil outbeacuse it will cause damage eventually to the big ends
PostPosted: Sat Mar 08, 2008 10:23 pm
The Nude Numpty
The Nude Numpty
PostPosted: Sun Mar 09, 2008 11:15 am
PostPosted: Sun Mar 09, 2008 4:34 pm
PostPosted: Sun Mar 09, 2008 11:32 pm
he cant get the sump bolt out.....i struggled iwht this when doing an oil change......put your fut against a wheel or the subframe and pull as hard as you can with a socket set....worked for me, try some WD40 5 mins before doing it :)
PostPosted: Sun Mar 09, 2008 11:37 pm
PostPosted: Sun Mar 09, 2008 11:40 pm
PostPosted: Sun Mar 09, 2008 11:43 pm
PostPosted: Sun Mar 09, 2008 11:48 pm
PostPosted: Mon Mar 10, 2008 10:23 am
Users browsing this forum: No registered users and 84 guests
