Fiesta-Si.com • View topic - Heater
 Post subject: Heater
PostPosted: Tue Feb 19, 2008 6:52 pm
Hey not long had my Si ( 1.25 Zetec Si 16v) its my first car :]
and heater seems to have packed in. Still get cold air blowing through fine (not needed in this bloody weather atm). Possibly dial has come away from connection on other side. Cant seem to get my Kenwood system out to unscrew panelling tho to see if i can fix it this way. Any other possabilities?
PostPosted: Tue Feb 19, 2008 6:59 pm
could it be the heater control valve located in the scuttle panel?
just an idea
Gf 01plate KA did the same, might have been a similar part?
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Tue Feb 19, 2008 7:00 pm
welcome to fsi
your heater could be due to your temp sensor going
PostPosted: Tue Feb 19, 2008 7:19 pm
PostPosted: Tue Feb 19, 2008 8:24 pm
how wud the temp sensor cause the heater to blow cold air
PostPosted: Tue Feb 19, 2008 8:34 pm
Where did temp sender come into this? :lol:
Its heater valve, easy to change, 4 hose clips, undo, pull of pipes, disconnect wiring. Put back together.
Do yourself a favour, buy a ford one; Originally, ford had lots of proplems with these, Ford have revised it with a new part number, however many motor factors still sell the part which is the same as the old one, not the revised one. ;)
PostPosted: Tue Feb 19, 2008 9:02 pm
PostPosted: Tue Feb 19, 2008 9:20 pm
PostPosted: Tue Feb 19, 2008 9:56 pm
