Fiesta-Si.com • View topic - Misfire at tickover
 Post subject: Misfire at tickover
PostPosted: Thu Feb 14, 2008 1:40 am
PostPosted: Thu Feb 14, 2008 2:04 pm
The Nude Numpty
The Nude Numpty
PostPosted: Thu Feb 14, 2008 2:33 pm
PostPosted: Thu Feb 14, 2008 2:49 pm
The Nude Numpty
The Nude Numpty
PostPosted: Fri Feb 15, 2008 4:36 pm
idf is the early zete common problem sticking valve m8 try doing an oil change have u recentlky done an oil change, have u put the correct grade of oil in 5w 30 because the incorrect grade will cause the valves to stick
PostPosted: Sun Feb 17, 2008 6:27 pm
PostPosted: Tue Feb 19, 2008 12:45 pm
PostPosted: Tue Feb 19, 2008 5:18 pm
PostPosted: Tue Feb 26, 2008 2:38 am
Done the oil change today and have done a few miles since the change and there doesn't seem to be any change. Had listen to the engine today, i can hear a ticking from the rocker cover while the car is missfiring then as i rev it the ticking disapears when the missfire goes. Just a thought but do the zetec engines have the hydraulic lifters like the old cvh engines? Could it be that one of the lifters is leaking and is not opening or closing the valve properly at low revs? Any ideas guys?
Cheers
PostPosted: Tue Feb 26, 2008 11:58 am
PostPosted: Tue Feb 26, 2008 2:35 pm
Nah its definately not the exhaust gasket its a definately metalic ticking. How easy is it to remove the lifters? Is it just a case of taking the cam off and then the lifter?
PostPosted: Tue Feb 26, 2008 2:39 pm
mine was making a ticking noise a while ago, i think mine got a little worse when i was accelerating but then went away, it turned out to my exhaust manifold gasket, it thought it was my tappets at first as it was a fairly loud metalic ticking noise
try the least expensive thing first, if its still doing it then go for the tappets etc.
PostPosted: Tue Feb 26, 2008 6:51 pm
PostPosted: Tue Feb 26, 2008 6:53 pm
PostPosted: Tue Feb 26, 2008 6:55 pm
PostPosted: Thu Feb 28, 2008 4:44 pm
could be injector m8 put a jack bar by each injector and check the sound of them if one is ticking faste rthan the other the injectors either need cleaning or replaced u need the injector seals aswell if u have them serviced
