Fiesta-Si.com • View topic - (crap idle issues) - update ;) sorted
It is currently Fri Mar 27, 2026 1:06 am
Post new topic Reply to topic  [ 97 posts ]  Go to page Previous  1, 2, 3, 4, 5
PostPosted: Wed Jan 16, 2008 8:46 pm
PostPosted: Wed Jan 16, 2008 8:57 pm
PostPosted: Wed Jan 16, 2008 11:25 pm
PostPosted: Fri Jan 18, 2008 3:45 pm
PostPosted: Fri Jan 18, 2008 3:52 pm
PostPosted: Fri Jan 18, 2008 3:56 pm
PostPosted: Mon Jan 21, 2008 8:00 pm
Wasnt the injectors after all
We took all the plugs out, unplugged everything, reset ecu
Adjusted the plug gap on the spark plugs and now its running how it was before, lumpy at idle, but now runs as good as before thank god.
So tomorrow going for a new temp sensor for the top of the thermostat like onslack had said before, as it seems to idle higher sometimes, so must think its cold.
and his other problem was timing a tooth out, but mines been checked and is spot on
so lets hope the new sensor will sort the original lumpyness out.
PostPosted: Wed Jan 30, 2008 6:24 pm
PostPosted: Sat Feb 16, 2008 3:53 pm
Not really done much else, apart from change the tps again
made no difference, and sometimes when ideling before it goes down around 1k as standard with its lumpyness, it will rev around 2k and i cannot make it go down unless i blip the clutch a little...
is there an incorrect way to fitting tps sensors?
PostPosted: Sun Mar 02, 2008 10:22 pm
PostPosted: Sun Mar 02, 2008 10:25 pm
PostPosted: Sun Mar 02, 2008 10:27 pm
PostPosted: Sun Mar 02, 2008 10:55 pm
PostPosted: Sun Mar 02, 2008 10:58 pm
PostPosted: Sun Mar 02, 2008 11:20 pm
PostPosted: Mon Mar 03, 2008 12:09 am
PostPosted: Mon Mar 03, 2008 12:12 am
