Fiesta-Si.com • View topic - tapping video
It is currently Thu Mar 26, 2026 12:47 am
Post new topic Reply to topic  [ 27 posts ]  Go to page Previous  1, 2
PostPosted: Fri Apr 20, 2007 9:39 am
PostPosted: Fri Apr 20, 2007 9:49 am
where are those on the manifold???? cheers scotty:)
PostPosted: Fri Apr 20, 2007 9:52 am
the EGR?
they look like probes (under the heat shield)
youll need a 19mm spanner to remove them :P
PostPosted: Fri Apr 20, 2007 10:14 am
jus a reference pic
 Post subject: Tapping
PostPosted: Fri Apr 20, 2007 5:40 pm
I would not have a garage do the job as it is dead easy. I am sure you have a mate who is handy with mechanics and has some tools ? Have a go yourself or get him to do it, if you do it you will save a fortune. It would take me about 30 mins to an hour max to do the job. but a garage will charge about 2 - 3 hours at between £15 & £30 per hour depending on the garage.
PostPosted: Sat Apr 21, 2007 12:19 pm
PostPosted: Sat Apr 21, 2007 4:27 pm
Take the rocker cover off mate. Also remove the front-drivers wheel after that and turn the crank pulley bolt clockwise with a 19mm spanner to turn the cams/tappets over if you can't see the ones that are down.
Removed my cover today to have a look for something, was dreading it but got it off pretty easily in the end, just need to refit it now haha.
Edit: It's definitely a dry tappet, I revved mine without the oil filler cap on, it squirted oil out at me and made the same noise
Users browsing this forum: No registered users and 114 guests
