Fiesta-Si.com • View topic - Easiest way to swap the engine? Lifting up or dropping down?
It is currently Mon Mar 23, 2026 5:27 pm
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2
PostPosted: Wed Feb 22, 2012 6:53 pm
ill be getting a crane so save pyay hassle...
PostPosted: Wed Feb 22, 2012 7:08 pm
Easiest way to do it :)
PostPosted: Wed Feb 22, 2012 7:10 pm
did you have to pop the driveshafts out danny?
PostPosted: Wed Feb 22, 2012 7:13 pm
I only took them out the inner housing thingy... cant think of the name now. Basically, I didnt pop them out the box, instead, took off the metal clip that holds the rubber gaiter on, then popped the gaiter off and pulled the shaft out the housing and tied them out the way. Just remember you'll need to drop the ball joint out the hub to allow them to be taken out
PostPosted: Wed Feb 22, 2012 7:21 pm
fuckkk me, didnt think of any of this :P i only have to drop the ball joint out of the hub to take them out of this 'inner house thingy'? this must be in the haynes right?
PostPosted: Wed Feb 22, 2012 7:24 pm
Yeah. Ball joint is 1 nut and bolt. 45mm torx (i think) one one end and a 17mm nut on the other... should come undone fairly easy :) its piece of piss.
PostPosted: Wed Feb 22, 2012 7:26 pm
ill take your word for it ;) just getting nervous now :)
PostPosted: Wed Feb 22, 2012 7:33 pm
Well, mine is because its been taken out about 50 times since ive owned it lol. Best thing to do is crack the nut first, then if the whole thing spins around, put the torx on the other end and undo it. Thennnnnn before the nut comes off, wind it back on a little bit, get a hammer, tap/whack the nut so the bolt moves, take the nut off and then tap it out.
It saves pissing around loads getting the bolt out if its a bit tight in there.
Im sure you knew that anyway ;)
PostPosted: Wed Feb 22, 2012 8:00 pm
yeah obviously you dope! :P what does the purple mean lad!? promotion...
looks like i have a lot of learning to do like
PostPosted: Wed Feb 22, 2012 8:05 pm
memberlist.php?mode=group&g=271 :thumbsup:
PostPosted: Wed Feb 22, 2012 8:14 pm
onto it! i am NOT jealous btw...
PostPosted: Thu Feb 23, 2012 9:09 am
Ahhh, I see you haven't mentioned the 5 hours worth of bashing the shit out of the hub to try and get the ball joint to pop? :lol:
PostPosted: Thu Feb 23, 2012 10:32 am
Nahhhhh I thought I would let him figure that out ;) :lol:
PostPosted: Fri Feb 24, 2012 12:50 am
im hard so it shouldnt be a problem...
PostPosted: Wed Mar 07, 2012 3:10 am
shell on its side and let it drop out ..... oh you were using it again :doh:
