Fiesta-Si.com • View topic - GAY idle and overfueling problem
It is currently Wed Mar 25, 2026 10:45 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
PostPosted: Sat Apr 23, 2011 7:18 pm
is the idle eratic like idling from 900 to 1200 on tick over and how do u know its notthe lambda unp0lugging it doesnt mean anything the sesnor may still be working but giving a weak signal try anothero ne if you can get hold of one or check it with a multimeter but i would be saying the lambda as i had the saem provlem on mine
PostPosted: Sat Apr 23, 2011 11:02 pm
I've narrowed my fez to the cat or lambda.
I've had belts/pulleys/ICV/filters/fluids/spark plugs/coil pack/MAF and ECU.
I've spent a couple of hundred getting to this point too, although tbf it needed a lot of what I've done.
PostPosted: Sun Apr 24, 2011 9:57 am
don't rule out your engine being fkd (i.e. low compression on 1cyl).
This happened to me, it used it idle erratically between 500rpm-1300rpm for the few 3-4minutes when starting from cold, and always stalled if you didn't dip your clutch quick enough at the first few junctions....
just a thought. not sure how mine happened, could have been my own doing when I swapped the cylinder head.....
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Sun Apr 24, 2011 12:49 pm
the lambda can actually cause engine damage normally they either give a signal where the engine will overfuel or underfuel run lean that will end up melting a piston or there will be hot spots on the cylinder bores and will eventually burn out the valves
PostPosted: Sun Apr 24, 2011 4:21 pm
PostPosted: Mon Apr 25, 2011 7:37 am
cud be throttle sensor
PostPosted: Wed Apr 27, 2011 12:17 am
dan mine is having a similar problem pops and bangs and soundss awesome but its not right it will idle but its 500-900 rpm and is over fueling a bit, im going to buy a idle control valve now theres plenty on ebay around £60, not sure how much genuine ford ones are though
PostPosted: Wed Apr 27, 2011 7:31 pm
£60? Jeez, never knew they was that much! lol
PostPosted: Thu Apr 28, 2011 8:05 am
wll if i get a long enough lunch break today im gona try and get one from fords will let you know how much it comes to dan :)
PostPosted: Thu Apr 28, 2011 10:54 am
ford are about £72 i went there the other day to get a new gasket for mine and asked about it
For a lambda sensor from ford is £160 :shock:
PostPosted: Thu Apr 28, 2011 4:53 pm
Lambda from Euro car parts is £60. I thought that was bad.
PostPosted: Thu Apr 28, 2011 5:13 pm
wats it run like if ya disconnect lamda and maf?
PostPosted: Thu Apr 28, 2011 5:29 pm
Over fuels even more with them disconnected
PostPosted: Thu Apr 28, 2011 5:45 pm
2.0l time
PostPosted: Thu Apr 28, 2011 7:22 pm
with a turbo
PostPosted: Thu Apr 28, 2011 7:26 pm
+ supercharger
PostPosted: Thu Apr 28, 2011 7:33 pm
+ carrot on a stick
PostPosted: Thu Apr 28, 2011 7:57 pm
Lambda from eBay £20
Catalytic Covnerter from eBay £60
Replacing both sorted my idle and overfuelling issues
PostPosted: Wed May 04, 2011 4:16 pm
All fixed now, believe it was the ISCV. Gave it a clean and it works now, idles perfectly and drives perfectly too!
