Fiesta-Si.com • View topic - Manifold meets cylinder gasket.
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2
PostPosted: Fri Feb 26, 2010 9:23 pm
yeah I think I may just get a spare set, just in case.
Thanks for the tip :D
PostPosted: Fri Feb 26, 2010 9:48 pm
good thinking woods, iirc the nuts you get new from ford are copper looking things, been a long time since i bought new ones :red: :lol:
worth buying a new set as well, as saod above just make sure you soak them with WD40 the night before
PostPosted: Fri Feb 26, 2010 9:52 pm
100 for a manifold gasket :lol: m8 it will only take u 20 mins spray some wd40 on the bolts leave the mto soka over night then go back to them try undoing the nuts its a 13mm socket 10 off them and clean the surfaces u shud be fine gasket round £7 :thumbsup:
PostPosted: Fri Feb 26, 2010 10:12 pm
Double that for me I'm mechanically inept :lol: especially with my dud right hand atm. Cut it up nicely when I was sorting the electrics behind the dash earlier (fog light, heater switch and stereo)
Onto my nest question.
A decent ford spares shop in Kent?
Hopefully within an hour of the M25 junction 6.
Don't mind it being a bit of a longer drive now I've sorted somethings out with the car.
PostPosted: Sat Feb 27, 2010 12:11 am
- Exhaust Manifold Gasket = £8.00 something
- Nuts = £82p per item (9 in total)
- Studs = £1.72 per item (9 in total).
it is quite costly to buy all new ...i'd personally get a few spare studs and nuts incase.
I done mine today and it was a big time pain in the ass. Reason being i didn't remove the manifold - i levered it away from the head to remove a stud (threaded for some reason). Anyway, generally the bolts wont' be to bad and if your lucky you won't have problems. I'd get a decent 'deep' 13mm socker though as it takes an age with spanners. Other than that plenty of WD40.
Hope this helps.
Andy
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Sat Feb 27, 2010 1:27 am
do you not have a ford parts place near to you then? the only ones i know of around near me are in redhill and crawley
when i used the one in redhill ages ago, the dudes there were mongs :lol: , the one in crawley is ok, but they one guy did have issues knowing what a mk1 frs was :hmm:
let us know how you get on :thumbsup:
PostPosted: Sat Feb 27, 2010 2:58 am
always have a can of WD40 handy. Stuff is good for most things.
Thanks for the prices of the bolts an studs. know roughly how much its going to cost now.
Someone remembered a ford place in catford so going to get the bits for it monday.
i will let you know how i get on :thumbsup:
PostPosted: Sat Feb 27, 2010 9:57 am
just re-read my post above and realised it made no sense at all...thats what beer does.
What i mean buy didn't remove the manifold, just levered it away from the head - i did remove the manifold from cylinder head, just kept everything else attached (i.e. down pipe etc), so it was very manoeuvreable once all nuts had been removed. this made removing the dodgy stud a nightmare due to space requirements.
Lol hope that clears it up :lolz:
RR - TBC
PostPosted: Sat Feb 27, 2010 12:22 pm
ok think I got what you mean on that one.
Either way makes sense to me, I've never done anything with a manifold before :lol:
PostPosted: Mon Mar 08, 2010 11:26 pm
ok so went to pick up the bits today but half are missing. They should be there for me to pick up in the morning with any luck.
Does anyone know where I can find the section that refers to changing or removing this section of the exhaust in the haynes manual.
I'm having a hard time finding it.
PostPosted: Mon Mar 08, 2010 11:56 pm
"Fuel & Exhaust Systems" has been chapter 4 in every Haynes book of lies I've ever looked at!
PostPosted: Tue Mar 09, 2010 11:41 am
I feel like a right thick one I've actually read through that chapter and still can't find it :doh:
it does reference removing the exhaust but not the bit I'm after, nothing like going in blind I suppose :lol:
PostPosted: Tue Mar 09, 2010 12:08 pm
you just got to undo the downpipe nuts with the springs on, just take note on how they come undone
then soak all the nuts on the manifold with w40 then go back and undo them all, remove the manifold and gasket and put your new manifold gasket on and then put the manifold back on and connect and do the downpipe back up :thumbsup:
only thing that might end up being a pain is the EGR :squint: , i hate thing thing with a passion :hmm:
i dont think i took any pic's when i did mine
PostPosted: Tue Mar 09, 2010 1:48 pm
nevermind.
Went to the place today and the bloke behind the counter had ordered the wrong bolts (I knew as I'd just replaced both of the ones with the spring on previously) He then tried to convince me they were the right ones/
The only thing correct was the gasket, nothing else was. Also he'd charged me for the downpipe thing and it hadn't turned up.
Fed up with being messed around, so just said give me my deposit back and left.
I'm now going to pay for the garage to do it, even though its going to cost me double :squint:
