Fiesta-Si.com • View topic - hi i have a poorly si
It is currently Thu Mar 26, 2026 8:52 am
Post new topic Reply to topic  [ 56 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Wed May 20, 2009 8:59 am
PostPosted: Wed May 20, 2009 2:38 pm
http://www.rikmarot.dsl.pipex.com/fiest ... apics.html
PostPosted: Wed May 20, 2009 3:33 pm
Burning oil somewhere then.
Could be piston rings, valve seals, something along those lines :(
How many pistons chambers is it happening in?
PostPosted: Wed May 20, 2009 6:54 pm
2 and 3
PostPosted: Thu May 21, 2009 7:05 am
hmm.......
sounds to me on the smoke that the rings may have started to wear.....
So was it running fine on the current ECU beforehand?
Good luck at the garage, i'd hazard a guess at overfuelling and worn rings :( possbily on the overfuelling, it sounds similar to jamie cliffe's Si wheh his O rings had gone on the injectors like onslack said :thumbsup:
PostPosted: Thu May 21, 2009 7:50 am
Yes shes ran fine for 4 years on that ecu mate. Everytime ive taken it to a garage they always blame the ecu and the chip. Even to the point where they put a spare ecu on. 200 quid later the car came out sounding and running just as bad as when she went in. another garage found a plug near the efi half in half out, yes ive checked that as well lol. The problem i have is the garage where she is now. Does all my m.o.t and other work. But he cant plug it in. His thoughts are the injectors. But dont want to start renewing them incase its not. Ill just have to wait for her to be plugged in tomoz :( very frustrating
PostPosted: Thu May 21, 2009 7:54 am
yeah if it ran fine its odd....maybe it is injectors :)
and if you could source a desk deep or dewy ecu just in case that may be worthwile :thumbsup:
and i bet its frustrating :doh:
PostPosted: Thu May 21, 2009 8:27 am
where abouts are you in the country?
only thing at the mo is to wait and see what the test brings up and got from there
PostPosted: Thu May 21, 2009 10:45 am
Im in notingham mate. cant wait for 2moz lets hope they know what there doing
frustrated frustrated frustrated :x :x :x
PostPosted: Fri May 22, 2009 10:57 am
Right the guy from the garage has just rang me. Said its the ecu. So i asked him to have alook at what ecu it was, He said thats going to be half hours work at 22 pound 50 plus vat ffs so as soon as i know what ecu it is ill be asking you guys if you have one for sale :) cheap lol
PostPosted: Fri May 22, 2009 11:01 am
hopefully it gets sorted soon then :)
PostPosted: Fri May 22, 2009 11:44 am
The ecu is defo a blob if anyone has one spare for sale wink wink
PostPosted: Fri May 22, 2009 12:13 pm
You paid them £22.50 to check what ECU it was?? :0 :doh:
Get the car back, pay them nothing more, and get yourself a proper ECU for it... and change it yourself! Piece of piss! :D
PostPosted: Fri May 22, 2009 2:28 pm
Got the car back he charged me £40 for plugging it in and checking what ecu is on it. I found a ecu on ebay 20 quid
PostPosted: Fri May 22, 2009 3:43 pm
TBH you'll struggle to find an ECU if it's desk/deep/dewy you're after.
have the garage done a compression test on the engine?
what leads are being used? genuine ford ones?
are the spark plugs gapped correctly, 1.8mm
has timing been checked?
first things i'd be looking at. if none of that cures it blag a 1.6 ecu (GURU code) and see what it runs like on that.
any questions just ask.
PostPosted: Fri May 22, 2009 5:12 pm
The car has run fine for 5 years on a blob ecu. thats what i have brought a blobthats being done wednesday and the coil pack is being done tuesday
PostPosted: Tue Jun 02, 2009 7:28 pm
Well the coil pack and ecu have been changed and it still flooding with pertrol. Going to change the injecters next. see what that does
PostPosted: Thu Jun 04, 2009 9:08 am
When you replace the ECU do you have to run it for a while or should it work straight away????
PostPosted: Thu Jun 04, 2009 4:47 pm
iirc when you've swapped the ecu over it should fire up straight away, but for the first few mins it'll be in like a "learning" mode, if your able too you should then take it for a spirited drive so it learns all the fuels bits etc.
PostPosted: Sat Jun 06, 2009 11:47 am
Just been to the garage where my baby is. Shes had 2 new injectors and o rings on 2 and 3. new ecu new fuel filter and a new set of good plugs. Shes now ticking over but still a bit lumpy and shes popping, What do you peeps sujest to do now, i was thinking of getting the chip remapped?
