Fiesta-Si.com • View topic - decomp info, cant remember to save my life
It is currently Fri Mar 27, 2026 1:06 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Wed Aug 06, 2008 2:14 pm
PostPosted: Wed Aug 06, 2008 6:34 pm
sorry guys have to agree with sisisisi as i have built a 2.0 zetec turbo with ferriday de-comp plate and when researching found this
http://www.ferriday.co.uk/cnc/decompres ... ates.shtml
which states
When using a Decompression Plate - only one head gasket must be used. All that is needed to seal the plate is a thin smear of high temperature non-setting sealant around the water & oil galleries between the 2 metal surfaces only. Let the conventional head gasket do its job in exactly the same way, as if the spacer plate wasn’t there. Don’t forget that with OHC engines it may be necessary to use a vernier pulley to allow correct cam timing settings. It is not necessary to anneal a decomp plate.
two headgaskets creates two weak points because the head torque setting are altered to an unknown quantity because of the squashable nature of the gaskets and lowers the compression ratio further than expected.
Cheers
Andy
PostPosted: Wed Aug 06, 2008 6:41 pm
PostPosted: Wed Aug 06, 2008 6:51 pm
after all this crap I might just do my ZT properly :lol:
PostPosted: Wed Aug 06, 2008 6:56 pm
Buy Terrys bottom end! :)
PostPosted: Wed Aug 06, 2008 7:00 pm
PostPosted: Wed Aug 06, 2008 7:02 pm
Think he mentioned to me thats he may be selling the head to someone! :)
Although you said you wanted to keep it 1800 and his engine is 2l! :(
PostPosted: Wed Aug 06, 2008 7:06 pm
PostPosted: Wed Aug 06, 2008 7:12 pm
lol good choice. i had the decomp plate but never really trusted it, no real reason why. but changed to forged low comp pistons and 2.1 for peace of mind and because i want around 400bhp in the next stage of tune
PostPosted: Wed Aug 06, 2008 7:14 pm
What happened to the heart of it allways being a RS1800! :nono: :lol:
PostPosted: Wed Aug 06, 2008 7:17 pm
PostPosted: Wed Aug 06, 2008 7:20 pm
or because i have everything but the ecu and injectors... i could just do the 1.8 to start with on decomp and see what happens. goes tits up i can do it proper :P
PostPosted: Wed Aug 06, 2008 9:55 pm
PostPosted: Wed Aug 06, 2008 11:15 pm
PostPosted: Thu Aug 07, 2008 8:13 am
PostPosted: Thu Aug 07, 2008 9:19 am
PostPosted: Sat Aug 09, 2008 11:35 pm
IF you have to use one ( which to be honest i wouldnt as you loose alot of the "squish " area in the combustion chamber ) one headgasket is the way they were original designed to be used. The block should be decked and the decomp plate fitted to that with a sealant of a type, then the headgasket fitted to the head side.
the cheaper way to do it is 2 headgaskets, but remember thats going to lower the CR even more and you are going to loose even more of the squish ability of the head leading to a less efficent burn
HTH
