Fiesta-Si.com • View topic - revving/juddering update
It is currently Fri Mar 27, 2026 7:08 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2
PostPosted: Wed Apr 16, 2008 1:15 pm
ok, bit of an update
i went an bought a lambda sensor today, not a bad price
fitted it within 30mins (piece of pee pee to do)
and it's still doing it
so im going to solder (sp) the wire if i can find my dads soldering iron...
they try again
if it doesn't work then im think the cat may have collapsed...
as it only struggles under load
anyway just a thought
thanks for the replies so far
andy
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Wed Apr 16, 2008 1:19 pm
The Nude Numpty
The Nude Numpty
I expect you know this anyway, but give the cat a good smack realy hard and see if you can hear anything jingling around in it. My advise is if your not sure take it off and have a look, not a massive job. If it is fucked Id smash all of the inside out with a bar or something and then buy a new one for the MOT, swap them over afterwards and you then have a home made de-cat. And if your buying a new cat anyway it didnt cost you anything!
PostPosted: Wed Apr 16, 2008 3:27 pm
i do want to do a home-made de-cat and am looking out for a cheap cat now anyway. i have gave it a gentleish prod with a breaker bar (didn't have much leverage) to no real avail..
i was wondered if it collapsed and begun to melt, and then hardened, therefore it wouldn't jingle? but i dont know why it would melt so thats probably a load of tosh :lol:
other suggestions have been cps and crank position sensor. dont like the sound of the crank position sensor...
would it help if i got a video of what it did up?
andy
RR - TBC
PostPosted: Wed Apr 16, 2008 7:14 pm
The Nude Numpty
The Nude Numpty
I thought crank position sensor and CPS were the same thing :? :?
PostPosted: Wed Apr 16, 2008 7:17 pm
i think cps is cam position sensor....not sure though
someone is more than likely going to enlighten us on this..
RR - TBC
PostPosted: Wed Apr 16, 2008 7:28 pm
CPS is Crank position sensor and i doubt it would be that, as it wouldn't start if it was that!
Could be something to do with the spark, plugs leads or Coilpack! :)
PostPosted: Thu Apr 17, 2008 8:45 am
really u could be guessing all week best thing to do is get it plugged in m8 but that wire doesnt look healthy as that one of the main cables to fire the coil pack and wont be doing it any favours iwould go to scrappy and get a new plug and chop that one out fo the loom i would also check for other breakeges in the loom
PostPosted: Thu Apr 17, 2008 2:03 pm
I'd get a friend over with the same car *hints at you guys to offer* so you can start swap testing things like leads,plugs,lambada and coilpack etc. If that doesnt do it couldnt it be a collasped cat?
PostPosted: Mon Apr 28, 2008 5:48 pm
bit on an update today...
had the MOT center have a look today as i went in for my re-test...
they said the coilpack wire looks intact and said this to me (which i nearly laughed at)
(HIM)"looks like someone's messed around with some pipes in the bulkhead... theres pipes missing.. and its been quite seriously messed with by someone..."
(ME) "Pipes missing? :shock: ... Ohhh you mean the EGR?"
(HIM) "Yea..."
(ME) "Yeah i took it off, it's a fairly pointless system, had it off for a while long before the problem occured"
(HIM) "Hmmm well that could be your problem, shouldn't have been taken off!"
(ME) " :sigh: Yeah ok, i'll look at it, Bye"
muffin!
anyways, had a little poke around when i got it home and found (what i think) maybe the problem!
this is a plug located behind (to the right hand side) of the inlet manifold...
looks badly damaged and several wires are broken in it...
i followed it and think it leads to the plug for my coilpack (ironically)...
other end dissapears into the bulkhead...
i think this may be the cause... but it wouldn't all of a sudden break therefore im unsure if this could be it... either way going to get it sorted a.s.a.p.
andy
RR - TBC
PostPosted: Mon Apr 28, 2008 9:37 pm
so i take it i was right andy breakeage in the loom them wires i think go to the injection system and other sensors
PostPosted: Mon Apr 28, 2008 11:24 pm
looks like it, just abit werid how the loom on my car is falling to pieces before me..
will investigate furthur, need to find a soldering iron first though
RR - TBC
PostPosted: Tue Apr 29, 2008 4:53 pm
Just get another engine loom and replace all that to save the hassle mate :)
PostPosted: Tue Apr 29, 2008 5:27 pm
looks like it fezzy, wait and see though this might not fix it..
would 1 wire cause such a big misfire?
paul - im thinking that...but my future plans are aftermarket management of some sort anyway which would consist of a loom anyway wouldn't it?
RR - TBC
PostPosted: Tue Apr 29, 2008 8:54 pm
depends what management you go for..
for example, I know if you get omex you get a loom made for your car
or if you go megasquirt you use the existing loom but chop your wires into it or use adaptor board
so depends :P
PostPosted: Tue Apr 29, 2008 9:36 pm
im bit of a cheapo so it'd probably be megasquirt...
i'd only need an engine loom, might keep my eyes open anyway
cheers for the comments
RR - TBC
PostPosted: Wed Apr 30, 2008 8:45 am
just restrip the wires back for now m8 and solder them togther just to get u out of the crap and then go searching for a loom wires will cause a missfire if there is a breage in them because its losing voltage lets us know
PostPosted: Wed Apr 30, 2008 1:41 pm
FIXED..
admittedly i've only crimped it and wrapped it electrical tape, but it does for the time being until i can get hold of a soldering iron.
thanks for the amount of replies, didn't realise this problem would be so random
cheers again
andy
RR - TBC
PostPosted: Wed Apr 30, 2008 1:53 pm
Glad to hear it's been solved! 8-)
PostPosted: Wed Apr 30, 2008 6:21 pm
least it can be used for time been now until ya get another loom or just leave it glad ya sorted it m8 :chill: :FSI:
