Fiesta-Si.com • View topic - Fiting alloys
 Post subject: Fiting alloys
PostPosted: Sat Oct 27, 2007 12:20 am
is it true that if i stik a set of alloys on my si i will need to get new wheel nuts??? can some one let me know about this
PostPosted: Sat Oct 27, 2007 7:07 am
u might want a locking set to stop someone making off with them
PM if u want u advert here :D
PostPosted: Sat Oct 27, 2007 9:24 am
you won't always need them, but i have found the longer nuts (chrome) are always easier.
and locking nuts as a must imo
L333SYA - Ford Cougar 2.5 V6
RR - TBC
PostPosted: Sat Oct 27, 2007 10:29 am
If you running steel wheels and are changing to Alloys then yes, new nut are needed 8-)
PostPosted: Sat Oct 27, 2007 12:27 pm
i thought u had to get certain wheel nuts for certain makes of alloys
PostPosted: Sat Oct 27, 2007 2:49 pm
to the best of my knowlege alloy wheel nuts are pretty std..there are a few diff types.... altho the std is a 12mm thread with a 60 degree conical seat.
the std alloy wheeluts will do..unless your buying wheels with group A inserts...in which case youll need specific nuts for that which are sleeved and the top collar is flat...so the centralisation is done by the sleeve part of the nut..not the conical part like normal nuts....but trust me...if id had the inserts...youd know about it ;)
Hope that helps in some way
Jam
PostPosted: Sat Oct 27, 2007 6:27 pm
PostPosted: Sat Oct 27, 2007 6:52 pm
