Fiesta-Si.com • View topic - Turbo on a N/A engien with 3 psi
PostPosted: Sun Oct 21, 2007 12:22 pm
PostPosted: Sun Oct 21, 2007 12:24 pm
PostPosted: Sun Oct 21, 2007 3:38 pm
avoid mtech like the plague!
 Post subject: dump valve
PostPosted: Sun Oct 21, 2007 5:24 pm
 Post subject: Re: dump valve
PostPosted: Sun Oct 21, 2007 5:51 pm
PostPosted: Sun Oct 21, 2007 7:44 pm
PostPosted: Sun Oct 21, 2007 8:28 pm
i wouldnt bother with 3psi. you will hardly notice it.
chatter is far better than the sound of dump valve anyway (which i have found out by removing mine )
PostPosted: Sun Oct 21, 2007 10:18 pm
Assuming its for your current engine setup...
You will need new cams, NA tuned cams usually have a slight overlap, any sort of forced induction on them would really f**k things up.
As mentioned, Get a FRST engine or a budget 1.8 zetec turbo, I would say a 1.8 as you can use a decomp plate and keep the standard pistons, this is advised on a 2.0 as the pistons won't take it.
PostPosted: Mon Oct 22, 2007 12:19 am
French Crew
French Crew
Untouchable
PostPosted: Mon Oct 22, 2007 12:14 pm
The Nude Numpty
The Nude Numpty
PostPosted: Mon Oct 22, 2007 1:15 pm
PostPosted: Tue Oct 23, 2007 6:31 am
