Fiesta-Si.com • View topic - Different Cams
 Post subject: Different Cams
PostPosted: Mon Sep 10, 2007 9:20 pm
PostPosted: Mon Sep 10, 2007 11:39 pm
PostPosted: Mon Sep 10, 2007 11:42 pm
PostPosted: Mon Sep 10, 2007 11:47 pm
PostPosted: Tue Sep 11, 2007 12:32 am
PostPosted: Tue Sep 11, 2007 12:36 am
PostPosted: Tue Sep 11, 2007 9:55 am
PostPosted: Tue Sep 11, 2007 10:19 am
PostPosted: Tue Sep 11, 2007 12:48 pm
reprofiling is good, matt you neccacerily need stronger sprins.. you can use cams with everythign standard.. but to make the most of it then your best bet will be to get solid lifters and srpings etc..
paul.. while all thats out... do the valve stem seals at the same time :P
PostPosted: Tue Sep 11, 2007 1:14 pm
Rightho
Cam kit on piper cams include: cams, followers, valve springs, timing disk and lube - £560 blank
or just cams, followers, timgin disk and lube - 325 repro, 520 blank
Can you give me a lil list of everything I would need , as I probably can't afford everything :lol:
PostPosted: Tue Sep 11, 2007 1:34 pm
PostPosted: Tue Sep 11, 2007 2:30 pm
PostPosted: Tue Sep 11, 2007 9:37 pm
PostPosted: Wed Sep 12, 2007 9:48 am
PostPosted: Wed Sep 12, 2007 9:14 pm
PostPosted: Wed Sep 12, 2007 10:44 pm
well.. how far do you plan on taking the engine..
all the way to thrtottle bodies.. high comp pistons and custom mappable etc?
if so then hell yes..
but if not its up to you £400/10 = £40 per 1bhp
PostPosted: Thu Sep 13, 2007 9:22 am
PostPosted: Thu Sep 13, 2007 10:00 am
PostPosted: Thu Sep 13, 2007 10:12 am
there not that expencive.. if you have them properly tuned etc
but running any modified engine will cost more.. as the manufactures (sp) designed them to last a while and be economical (to a degree)
PostPosted: Thu Sep 13, 2007 10:46 am
Hmm fook knows what to do then :lol:
