Fiesta-Si.com • View topic - modding mondeo tb to fit
 Post subject: modding mondeo tb to fit
PostPosted: Sat Jun 09, 2007 8:27 pm
jst wondering what is actually involved when u need to mod it as i did have look and sensor is in the way and the swinging arm bit goes wrong way
anybody got pics of theres ?
thanks
garry
PostPosted: Sat Jun 09, 2007 10:32 pm
PostPosted: Sat Jun 09, 2007 10:35 pm
PostPosted: Sun Jun 10, 2007 1:16 pm
PostPosted: Sun Jun 10, 2007 6:59 pm
Il get a pic of mine, had to file some bit/angle grind it.
PostPosted: Mon Jun 11, 2007 8:17 am
PostPosted: Mon Jun 11, 2007 3:20 pm
Zetec Mapping Services
PostPosted: Tue Jun 12, 2007 6:44 pm
You need to swap the linkage over, swap the TPS sensor round,
then the throttle cable braket,; The bottom hole lines up and bolts in, however the one on the side, you need to angle grind part away so theres not actually a hole but a bit for the bolt to sit in and hold braket.
Hard to explain, but look at the pics
PostPosted: Mon Jun 18, 2007 8:21 pm
PM if u want u advert here :D
PostPosted: Mon Jun 18, 2007 8:32 pm
PostPosted: Mon Jun 18, 2007 8:34 pm
PostPosted: Mon Jun 18, 2007 8:40 pm
well when i ran the 1.6 throttle body revs were restriced and acceleration was little slow !!
now i have fitted the 2litre throttle body you notice alot of difference to the cars speed and acceleration as the 2litre one has a larger bore size and butterfly is allowing the correct amount of air thro as it was meant to !
PostPosted: Mon Jun 18, 2007 8:48 pm
so u'd recommend modding the 2l TB them m8?
was it hard to do?
PostPosted: Mon Jun 18, 2007 9:00 pm
PostPosted: Mon Jun 18, 2007 10:04 pm
aint got a 1.6 TB, i may however aquire the parts the next time im at the scrapies ;)
PostPosted: Tue Jun 19, 2007 12:30 pm
PostPosted: Tue Jun 19, 2007 6:18 pm
