Fiesta-Si.com • View topic - would a escort rs turbo 'box be any good in a 2l fez?
It is currently Sat Mar 07, 2026 6:41 pm
Post new topic Reply to topic  [ 33 posts ]  Go to page 1, 2  Next
PostPosted: Fri May 11, 2007 7:32 pm
ive got the chance of a ESCORT MK4 RS TURBO gearbox, as my fez is off road for a 2l conversion i'll also need a 'box (car currently a 1.1), would this 'box be better or worse than a si 'box?
PostPosted: Fri May 11, 2007 7:58 pm
Longer ratios with a limited slip diff...
Zetec Mapping Services
PostPosted: Fri May 11, 2007 8:01 pm
thats a yes then?
PostPosted: Fri May 11, 2007 8:03 pm
The LSD is nice to have, especially if you're into drag racing...
The ratios though.. slower acceleration, faster top speed..
PostPosted: Fri May 11, 2007 8:37 pm
mmm, its accelerration im after, like to nail it up to 60-70, would hardly ever be flat out, thats when the mondy st comes in handy :)
PostPosted: Fri May 11, 2007 8:38 pm
Then the 1.6 box has better ratios for you..
PostPosted: Sat May 12, 2007 12:00 am
I'd go for the rs box if you are planning to modifi the engine further
PostPosted: Sat May 12, 2007 1:00 am
PostPosted: Sat May 12, 2007 9:20 am
The Si comes with an IB5, and yes it is better than the RST (BC/B5) box. Ultimately, as above, putting the RST LSD in the Si's IB5 would be ideal.
PostPosted: Sat May 12, 2007 4:31 pm
I think the Si box would be way too short. Its too short really for the 1.6 so a lot of potential would be lost from the 2.0. I find the S2 RST box has perfect ratios, and the LSD makes things a million times better
PostPosted: Sat May 12, 2007 5:29 pm
PostPosted: Sat May 12, 2007 7:40 pm
PostPosted: Sun May 13, 2007 3:08 am
PostPosted: Sun May 13, 2007 10:51 am
Er.. righto
PostPosted: Sun May 13, 2007 12:16 pm
i used to run the Si box and now run the S2 lsd box in mine and i have to say i prefer the S2. Yeah ratios are a little longer for getting away but it well worth it when you get to some corners and motorway is much nicer than the Si box reving the nuts just to do 80mph.
PostPosted: Sun May 13, 2007 7:03 pm
PostPosted: Sun May 13, 2007 7:05 pm
PostPosted: Sun May 13, 2007 7:21 pm
The Nude Numpty
The Nude Numpty
Well if you want to get really into it then you are wasting energy with a shorter ratio. Because the gearbox isnt 100% energy efficent, if it is revving more to attain the same speed, then more energy is gunna be wasted as noise/heat etc. But obviously that is gunna be a pretty small % difference between the two boxes, im just waffling lol.
PostPosted: Sun May 13, 2007 7:23 pm
At the end of the day it's all pointless unless we understand what the original poster means by "better". To him, faster acceleration might be 'better', in which case the shorter box is superior. Or perhaps he wants best fuel economy at 80mph, in which case diesel ratios would be superior.
PostPosted: Sun May 13, 2007 7:33 pm
