Fiesta-Si.com • View topic - Front Speakers
It is currently Fri Mar 06, 2026 5:29 pm
 Post subject: Front Speakers
PostPosted: Thu Jan 04, 2007 5:50 pm
Sig. made by xmadxmoex
PostPosted: Thu Jan 04, 2007 6:36 pm
Personally i rate JBL quite highly, always had a decent sound from them and theyve taken all the abuse/ bass i've thrown at them and they are a reasonable price.
Also recommend Vibe or Fli if your on a budget.
Think you need speaker pods to fit 5.25's in the front doors, sameas the back.
Components have the tweeter seperate from the main speaker, helps the sound stage, would highly recommend these.
If you dont want subs etc, get a pair of 5.25's for the front and a pair of 7x10's for the shelf, ideally in a stealth shelf, should keep you more than happy like that. Oh, and a 4 channel amp to give it some juice!!
HTH
PostPosted: Thu Jan 04, 2007 7:44 pm
PostPosted: Thu Jan 04, 2007 7:46 pm
PostPosted: Thu Jan 04, 2007 8:14 pm
PostPosted: Fri Jan 19, 2007 11:36 pm
What ones are the best out of these?
http://caraudiosecurity.com/shop/produc ... /4885.html
http://caraudiosecurity.com/shop/produc ... /2851.html
http://caraudiosecurity.com/shop/produc ... /5328.html
http://caraudiosecurity.com/shop/produc ... /5647.html
http://caraudiosecurity.com/shop/produc ... d/506.html
Sorry there is alot of links, but i am really undecided, and will these fit straight in an Si?
PostPosted: Fri Jan 19, 2007 11:38 pm
I believe for the Fiesta you need Speaker adaptor plates to fit after market speakers.
Oh and i'll go for the JBL ones but thats just my opinion mate.
PostPosted: Fri Jan 19, 2007 11:45 pm
ok, where would i get them from? is there no way i could get them to fit without getting them? what size are standard speakers? 13cm?
PostPosted: Fri Jan 19, 2007 11:46 pm
i think they sell them aswell, i just looked :)
PostPosted: Fri Jan 19, 2007 11:57 pm
if you look in the max power and haynes collaboration of the maximum guide to modifiyin your fiesta
in there it tells you to change all speaker wires to proper speaker cable and that if you want u can fit larger speakers by redrilling the holes so that they are screwed on tight.
also make sure you use the sound deadening tape stuff place it around the speaker plate bit and put some onto the door panel this will give you a better sound within the car and make sure all those beats are directed at the passenger nd driver
PostPosted: Sat Jan 20, 2007 12:18 am
Think you can get an amp, 6x9 and front speakers package for £99 iirc in one of the car mags and/ or a sub.
